Results 1 to 4 of 4
Thread: Melbourne source for compression fittings/teflon tubing?
    Sep 2009
    7
    Long time lurker finally picked up a machine from another member (Imat Junior); at last I no longer need to scour the for sale forum every day!
    In the spirit of inquiry, I decided to tear it to pieces - all fine except Id never seen a compression fitting before and my curiosity got the better of me. Side cutters Vs pump-to-boiler plumbing - no competition! Now Id like to replace the mangled tubing and olive (the elbow joint survived).
    Tomorrow I will try Lygon Imports in Fairfield and Grinders on Lygon St; can anyone suggest any other suppliers in case Im out of luck? Id prefer to go somewhere in person, if at all possible.
    Thanks in advance,
    Mr Box
    Oct 2010
    483
    Re: Melbourne source for compression fittings/teflon tubing?
    Coffeeparts should be able to supply tubing (and probably fittings). Enzed or Pirtek will be able to get you the fittings if you cant find them elsewhere and they have stores peppered around the city. You could also look at Reece plumbing - pick one that does HVAC not just basic plumbing.
    Jul 2008
    Port Fairy
    2,993
    Pneumatics industry generally or even a good quality industrial supplier or bearing shop would be the best places to go.
    Sep 2009
    7
    Thanks guys, ended up going to Reece Plumbing as theres one that does HVAC just up the road from where I live. The machine is back together and working now (after a few blow outs from not tightening the compression fittings up enough - lesson learned!)
  1. Silvia Teflon Tubing
    By Alistair1 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th October 2011, 10:31 PM
  2. Source for 6.00mm copper or PTFE/teflon hose
    By mrbox in forum Brewing Equipment (non-machine specific)
    Last Post: 29th March 2011, 05:39 PM
  3. Tamp pressure effect on puck compression
    By gregpullman in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd March 2007, 11:23 PM
  4. Saeco parts source - Melbourne - open this weekend
    By Driverman in forum Brewing Equipment (non-machine specific)
    Last Post: 7th July 2006, 06:02 PM
