Results 1 to 4 of 4
Thread: Gasket
    Jun 2006
    754
    Gasket
    Hey,
    Im wondering how long a gasket can last for before changing it? (just curious) ;D
    Nov 2005
    112
    Re: Gasket
    I think it varies depending on how long you leave your machine on each day, something to do with hardening of the rubber?
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    848
    Re: Gasket
    Quote Originally Posted by Coffee Kid link=1151917682/0#0 date=1151917682
    Hey,
    Gday CK,
    in addtion to Bloops reply, it also depends on how you look after it (I assume youre referring to the group gasket). If you dont clean it after every use ie with the blind portafilter wiggle or using a damp cloth or brush, youll be grinding ground up coffee into the gasket every time you turn the portafilter handle. Imagine tiny rocks being forced into the gasket material :(.
    Apart from that, I dont think there is a standardised change gasket every x interval as there are too many factors impacting on its life span.
    If your routine is down pat, and nothing else changes, and suddenly your portafilter is leaking around the gasket area, its most likely time to change it.
    Hope that helps.
    Jun 2006
    754
    Re: Gasket
    I clean it after every use and i only turn it on when i need to use it :)
  1. Gasket on Giotto
    By AFallingCrate in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th April 2012, 05:01 PM
  2. Quaha Group Gasket
    By aldavo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 4th February 2011, 12:10 AM
  3. Gasket for stovetop Bialetti
    By beetle in forum Brewing Equipment (non-machine specific)
    Last Post: 13th May 2008, 09:54 PM
  4. Brew Gasket
    By Coffee_Kid in forum Brewing Equipment (non-machine specific)
    Last Post: 14th August 2006, 01:29 PM
