Results 1 to 4 of 4
Thread: Naked PF
    Jun 2008
    120
    Naked PF
    Hi All
    Is there any secret trick to getting the naked pf to flow without springing a leak so to speak.
    or is it the need to get it all right to make it work well?
    Nov 2010
    Melbourne, VIC
    185
    Re: Naked PF
    Quote Originally Posted by 6B616E6461373132000 link=1308480780/0#0 date=1308480780
    Spot on. If its not all right, it wont work very well.
    But there are techniques, like WDT which may help you.
    Roz
    Roz is offline
    Nov 2009
    Hobart
    327
    Re: Naked PF
    I assume you mean springing a leak in the pour not the seal? if water is coming from the sides of the portafilter the gasket may need replacing or the portafilter not locked in far enough.
    If you are getting gushers through the pour and coffee spraying all over the place that is channeling, the pressurised water will always find the least amount of resistance in the puck and If you have everything right this will not happen.
    Different things you do can produce channeling, this link explains it well http://www.ineedcoffee.com/07/naked-portafilter/
    I personally use the weiss distribution technique which reduces the chance of channeling, A decent fitting tamper also helps. The technique can be found here http://www.home-barista.com/weiss-distribution-technique.html
    Nailing channeling on the head puts you on the road to improving your technique and pulling better and more consistent shots.
    Jun 2008
    120
    Re: Naked PF
    R0s
    Thanks for the tip WDT was a winner
  1. Getting naked.
    By Yelta in forum Brewing Equipment (non-machine specific)
    Last Post: 27th November 2013, 06:33 PM
  2. Why go naked?
    By coffeelust in forum General Coffee Related...
    Last Post: 24th July 2009, 10:45 PM
  3. Naked PF?
    By gattyguy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 6th January 2009, 02:02 PM
  4. Naked or not?!
    By Zedd in forum Brewing Equipment (non-machine specific)
    Last Post: 18th July 2007, 09:08 AM
  5. can i go naked?
    By otherendup in forum Brewing Equipment (non-machine specific)
    Last Post: 12th July 2007, 07:53 PM
