Results 1 to 5 of 5
Thread: Using hot water in water tank for improved temperature stability?
    Jun 2011
    3
    Hi there!
    I was wondering if it would be a good idea to use hot water instead of cold water in the water tank of my espresso machine to improve temperature stability?
    14,666
    Re: Using hot water in water tank for improved temperature stability?
    Quote Originally Posted by 332A2B3C37382C3D590 link=1309728857/0#0 date=1309728857
    Hi there!
    No....Its designed to work with cold water.
    May 2010
    Sydney North Shore
    1,326
    Hello and welcome jsrenaud.
    To improved temperature stability, things can be done at the other end of the process. This is why many machine makers build in a PID or some owners add an aftermarket PID controller.
    Whats a PID controller? Well I just had to looked it up. PID stands for "proportional integral differential" and it relates to a process to continuously correct the temperature to avoid any large overshoots and undershoots that can occur with simple temperature control systems.
    You can still get good coffee without all this, but it is more difficult to be consistent.
    Enjoy your coffee.
    Barry
    Jun 2008
    1,520
    the water gets "warm" if you leave the machine on a long time anyway
    17,381
    Quote Originally Posted by 727E777A7A731F0 link=1309728857/3#3 date=1309735378
    And thats a BAD thing to do.... :(
  1. cleaning water tank and water carrying tubes of Rancilio Silvia from "gunk" ?
    By acid_rider in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st September 2012, 10:24 PM
  2. Water Tank probe
    By JohnA in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 30th June 2010, 01:18 PM
  3. Question about drawing water now that I have replaced the in tank water softner
    By barrel in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th August 2009, 09:43 PM
  4. Levetta water tank
    By MarkC77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th February 2008, 08:03 AM
