Results 1 to 4 of 4
Thread: Isomac Mondiale
    Mar 2006
    Perth
    32
    Isomac Mondiale
    Ive got one of these up on my bench on roadtest.
    Has anyone had a look at one of these
    14,665
    Re: Isomac Mondiale
    Yes- theyre a gorgeous looking unit.....am not quite sure about the wand controls though... How do you find them?
    MONDIALE
    FEATURES
    Stainless steel construction
    E61 group head
    Heat exchanger
    Thermo syphon circulation
    Semi automatic
    Steam & hot water outlets
    Automatic low water shut off
    Single & double portafillers
    Vibrating pump
    Cup warmer
    TECHNICAL DETAILS
    VOLTAGE 240
    POWER (W) 1400
    PUMP PRESSURE (atm) 12 - 14
    WATER TANK (lt) 2
    BOILER (lt) 2.2
    WIDTH (cm) 34
    DEPTH (cm) 48.5
    HEIGHT (cm) 43
    WEIGHT (kg) 25
    Mar 2006
    Perth
    32
    Re: Isomac Mondiale
    The ergonomics of the wand controls is great, flick the toggle lever any which way you like & you have full steam pressure. Gentle tap, it springs back to the centre & steams stops instantly.
    One downside is you cant regulate/control the steam pressure, its all or nothing.
    Ive gone from Silvia to this and the quantum leap in milk texturing has surprised me. I managed to get fantastic microfoam on my second attempt.
    The machine is running a bit hot, 1.3-1.4bar boiler & 9.5-9.75bar brew pressure, I might see if I can find info on adjusting it.
    Also Im not overly keen on the whole hx flush routine, so Im considering the Brewtus ( ;) Chris).
    Karl
    14,665
    Re: Isomac Mondiale
    Quote Originally Posted by KarlS link=1153099059/0#2 date=1153106369
    Karl *
    Hmm- I would have thought that 0.95-1.1 bar should have been adequate with a big boiler like that....As for pump pressure, 9.5 bar is not too bad....could be 8.5-9.0 however my demo Minore seemed to want a touch more....and I settled on 9.5 bar....
    As for the Minore (1 month away at the moment :-/) no problemo, however you will however still require a short initial (say perhaps 50-75 ml) warming flush with the Minore II/Brewtus...In between shots though, a short cleaning/rinsing flush is fine....
  1. Isomac Tea II or older Isomac Mondiale?
    By bean_roasting in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 2nd June 2010, 11:47 PM
  2. Isomac Mondiale
    By DavidR in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th October 2007, 10:17 AM
  3. ISOMAC MONDIALE
    By JAYDEE in forum Brewing Equipment (non-machine specific)
    Last Post: 6th September 2006, 08:49 AM
