Results 1 to 6 of 6
Thread: Tamper size...does it matter
    Sep 2010
    21
    Hi guys, how important is it to have the exact size tamper for your portafilter? if i get one thats a few mm too small will it have a large effect on the tamping/extraction?
    Senior Member artman's Avatar
    Jun 2006
    2,409
    Re: Tamper size...does it matter
    A few mm too small is quite a bit, and you probably will have lesser compacted coffee around the outer circumference of the basket. the water will take this path of least resistance and your centre of the basket wont extract much comparatively.
    There is a fair bit of info on this forum about this (search button top right) and a recent thread which will probably answer most of your questions:
    http://coffeesnobs.com.au/YaBB.pl?num=1312761557
    Jul 2008
    Port Fairy
    2,993
    YES it matters.
    0.5mm wont make huge difference but I have while waiting for some custom Pullman tampers in the past made do with one that was 1.5mm smaller and on another machine nearly 3mm smaller with a non smooth base. Both of these were painful to impossible to get a consistent shot with regardless of technique.
    Nov 2010
    448
    Quote Originally Posted by 6F686C636B617464636A0D0 link=1313812862/2#2 date=1313993470
    YES it matters.
    I can agree with this. I am struggling with an Expobar (58mm) while using a 57mm tamper at the moment. I can get it consistent, but have to tamp VERY carefully, turn, tap, tamp again. Too much stuffing around. New baskets/tamper on the way.
    Senior Member specialpants's Avatar
    Dec 2010
    310
    It probably makes a difference; I havent had anything that was more than 0.5mm of play (comparing tamp diameter to the inside diameter of the basket), and I just take peoples word for it.
    Quote Originally Posted by 3C23213B22372021364E0 link=1313812862/3#3 date=1313998859
    Off topic - Try doing it without tapping. I found the pour looked much better without tapping after the first tamp.
    Funny things happened if I introduced the tap into my tamping process. For me, I use to do the tap to dislodge grounds that were stuck on the wall of the basket. These days, I dont do this because I found that Id consistently get a jet of espresso shooting out on an angle from the portafilter.
    I believe this is one form of channeling, where water is rushing out and shooting with plenty of pressure from one specific hole in the basket. I think a lot of people on here recommend against the tap too (not too sure of their reasons though...)
    Nov 2010
    448
    Quote Originally Posted by 3D3E2B2D272F223E2F203A3D4E0 link=1313812862/4#4 date=1314002250
    Ill try this - it will become a moot point once I get the new tamper though, because there wont be any grinds left on the sides.
  1. Syphon - does size matter?
    By simskade in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 26th October 2011, 07:49 PM
  2. Does size really matter?
    By CraigA in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th March 2009, 10:18 AM
  3. Does size really matter? My new Doge 83.
    By Pavoniboy in forum Grinders
    Last Post: 1st February 2009, 12:47 AM
  4. Does SIZE matter?
    By Rolley in forum General Coffee Related...
    Last Post: 16th May 2007, 10:20 PM
