Results 1 to 9 of 9
Thread: Newbie with a Silvia
    343
    Hi Guys! Love the site....ordered my stater park and have my popcorn popper ready.
    Had a Saeco Via Venenzia but only kept it for a week as the pressurized portafilter gave me a headache.
    Have a Silvia now...love it. Have a question though....i have trouble with extraction and using the double basket into two glasses, the pour is uneven.One spout will have a nice pour but the other spout doesnt start for another 5-7 seconds.....not sure why. I notiiced my spouts dont line up 90deg to the handle if this makes sence....Anyone have the same problem
    Nov 2005
    52
    Re: Newbie with a Slivia
    its normal for the spouts not to line up to the handle, as for the uneven pour the only thing I can think of is that you havent tamped evenly. Are you using the plastic tamper that it comes with - its worth upgrading that... if your tamping is fine and you are sure the coffee is evenly distributed... well all I can think of is that either your machine is on a slight slope or there is something blocking the water flow, either below the basket (e.g. some tape on the basket) or above the showerscreen. Both seem unlikely to me. Or it could be something in the spout :-/
    There maybe another explanation which someone more knowledgeable than me will jump in with.
    Jul 2004
    2,131
    PhatBoy,
    Greetings from fatboy!
    Your issue is most likely one of 2 things.
    1. One of your spouts has a small amount of built up residue of some kind. Coffee, or coffee oils are the most likely sources. A poke around with a cotton bud sometimes helps.
    2. Your tamping is uneven. I only get a nice even extraction through the double when my dose and tamp is even. If you favour one side, that is the side that will pour first. If possible, check the puck afterwards and see if there is any channeling. This is also a sign of an uneven tamp.
    The non 90 degree lineup is not an issue. As long as you do not have water coming out of the area between the group head and the portafilter, all is OK.
    Brett.
    343
    Re: Newbie with a Silvia
    Thanks guys!
    It must be my crazy tamping with mr plastic tamper.
    Hi fatboy!!!!!!!!!!!! hahahahahaha tha IS THE FUNNIEST THING EVER!! CLASSIC!!
    Mar 2004
    118
    Ive seen this uneven pour on a couple of Silvias mine and another person who is no longer a member of CS.
    I solved mine by buying a commercial PF then ultimatley by running a hole saw through it and making it bottomless. That is a fascinating experiment well worth the time and effort.
    But the commercial filter handel fixed it but on the origonal handel the hole was drilled off centre.
    A commercial PF handle cost us $40 i think it was from the local Rancilio dealer.
    Rich
    Apr 2006
    4,126
    One thing I have noticed and you might be well advised to have a look at for yourself and that is check the way the water runs without the portafiller locked on. If the water runs to all of one side or another of the shower screen, there may actually be a problem with whether your machine is level or not.
    Out here on the black soil plains there is not a house that is level due to the ever changing and moving soil. So we have since discovered that our kitchen benches are not exactly flat and hence the machine tends to pour to the front of the screen. I used a small level on top of the machine and have since corrected the problem.
    Mar 2004
    118
    Yeah I had my silvia jacked up on one side for a while but the 6900 has adjustable feet on the front. :)
    May 2005
    237
    Rich and Rae, how do you compare your Silvia to the Sumbeam?
    Jun 2004
    283
    Im surprised nobody has offered this advice yet. Stop pouring half your coffee into the second glass ! I could never go away from double-shots now, particularly as I, like most people here, tend to cut them short as a hint of blonding occurs.
    Of course, the biggest change you will get is to buy yourself a proper tamper, and throw the plastic thing away. Better still, keep it in case you ever want to sell Miss Silvia and upgrade, that way you can keep your solid tamper and not have to sell it inclusive.
  1. Newbie Silvia questions
    By Pobie in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th June 2012, 11:07 AM
  2. newbie silvia question
    By headinclouds in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th May 2011, 04:38 PM
  3. Newbie - Silvia + Rocky
    By carlli in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th July 2009, 10:24 PM
  4. Please help newbie with Silvia
    By critterjg in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th March 2009, 06:15 PM
  5. Newbie Silvia Owner
    By ricster in forum Brewing Equipment (non-machine specific)
    Last Post: 20th November 2005, 11:18 PM
