Results 1 to 7 of 7
Thread: Tampers, convex base Vs flat base
    Jun 2006
    Williamstown Victoria
    85
    Having recently dipped my big toe into the murky depths of*the world of tampers, I have discovered that some prefer a flat base and others convex. *As the great professor once asked. Why is it so? I would be interested to hear your thoughts on the pros and cons of both.
    Bart.
    Jul 2004
    2,134
    Re: Tampers, convex base Vs flat base
    Bart,
    I remember reading some articles a couple of years ago regarding this .
    I think it was on coffeegeek, so perhaps a search there might turn something up.
    There seems to be passionate arguments on both sides.
    Ive only ever used a flat one, but I certainly have no complaints.
    I can heartily recommend the Greg Pullman version.
    May 2005
    1,964
    Quote Originally Posted by fatboy link=1154345555/0#1 date=1154346808
    Yeah, and Im not really sure why ...
    My $0.02; the shape of your tamper bottom has to be about the gazillionth item on the list of most influential things in the spro process. Distribution and not dicking around doing too many taps, re-tamps, half-tamps and polishes seem to make much more of a difference.
    The only somewhat vaguely conclusive anecdotes that I can give are that when it gets REALLY busy I tend to reach for the convexes and things seem to be more consistent for me. At home I have one flat and two convexes (only slight convexes) and it is the latter two that get the biggest workout ... although probably because they are the most ergonomic for me. At work we have about five or six, of which only one is flat, and we almost never use the flat. St Alis superstar barista, Toshi, uses a Tobira flat based tamper.
    Luca
    Dec 2005
    122
    I wont pretend to know the answer to this one. Many people more qualified that myself have answered this one already and it seems to come down to personal preference. What I can comment on is observation. I purchased a Reg Barber combination (flat, US convex, and Euro convex) and a Greg Pullman flat tamper. I figured I play with each type and come up with my own preference.
    The Pullman is by far the most impressive looking and feels great in the hand. However, I have only had it a few weeks so havent given it a fair go yet. The one tamper that consistently results in better extractions at the moment seems to be the US convex tamper. Ive observed that the shower screen shape on the minore is similar to the angle of the US convex tamper. Maybe it has to do with this, or maybe it is my technique.
    Id like to play with each of the tampers for a few more months before making any conclusions.
    Jun 2006
    BRISBANE
    2,001
    I have a flat and a convex, but Im not experienced enough to have any idea if there is any difference. Should the tamp have a couple of mm gap on all sides to the inside of the basket? Mine does.
    Jun 2006
    85
    While Im unable to get a definitive answer on flat Vs convex, it seems to be universally accepted that the less gap between the edge of the tamper and the basket, the better. A large gap creates uneven pressure across the puck, allowing for channeling, which is when the pressurised water takes the path of least resistance through the ground coffee, creating a channel and resulting in under extracted coffee. Hence the reason why specialist tamper manufacturers like Greg Pullman strongly advise custom fitting your tamper to the basket, ensuring almost no gap at all.
    Bart.
    Jun 2006
    BRISBANE
    2,001
    cheers mate
  1. Convex vs Flat base tamper
    By bigmomma in forum Brewing Equipment (non-machine specific)
    Last Post: 23rd January 2009, 02:33 AM
  2. Reg Barber base swop. 58mm Flat for Convex
    By E-Gene in forum Brewing Equipment (non-machine specific)
    Last Post: 29th July 2008, 12:09 PM
  3. Convex vs Flat Base Tamper
    By jchiha in forum Brewing Equipment (non-machine specific)
    Last Post: 26th December 2005, 04:19 PM
