Results 1 to 3 of 3
Thread: In-line resin water filters
    Dec 2011
    9
    Hi
    Im an newbie about to buy my first real espresso machine. I have read the water filter stickie, but it didnt really answer my question.
    Im doing a renovation with completely new kitchen and dont really want to set up a full water softener system just for the coffee machine. I just bought a reasonably expensive fridge with water filter/ice dispenser so for me another filter for dedicated drinking water is a waste of money/bench space.* The wife definitely doesnt want another tap on the sink.
    I also dont want to put a water softener in the fridge drinking water supply line, as I dont actually like the thought of taking out free calcium & magnesium from my drinking water. Not sure if it sounds irrational, but I do a lot of exercise and I see these electrolytes as beneficial, even if they do harm machines.
    I have seen the inline resin filters that Isomac machines use that can be fitted to other espresso machines. Theyre also pretty cheap, even if they need to be replaced/recharged periodically. Much cheaper than full Brita etc systems. I was hoping this might solve my problem.
    Will using an in-machine resin filter alone be effective in softening the water, or do I really need to get something external/under the sink?
    Any tips appreciated.
    Dec 2011
    9
    Re: Water filtration question
    PS..my water supplier is City West Water in Melbourne. They suggest the average total hardness is 30mg/L with a max of 50mg/L, which I understand is quite soft already.
    Senior Member artman's Avatar
    Jun 2006
    2,411
    Re: In-line resin water filters
    My understanding is that the inline resin filters that go on the machines suction tube in the tank do a decent job in regard to prevention of scale build up, as long as they are recharged/replaced as required.
    If you want to install an under bench system (which you can also use for cooking, kettle etc), you can now get kitchen taps that incorporate a filtered water outlet, so you dont end up with 2 taps on the bench.
  1. Pure Water water filters
    By chrislng in forum General Coffee Related...
    Last Post: 18th December 2012, 07:34 PM
  2. Rancilio s27 - boiling water line seems blocked
    By towe0609 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 18th April 2010, 02:50 PM
  3. ION exchange resin filters
    By adharvey in forum Brewing Equipment (non-machine specific)
    Last Post: 10th June 2009, 06:16 PM
  4. Water softening ion exchange resin
    By Paolo in forum Brewing Equipment (non-machine specific)
    Last Post: 7th May 2007, 09:05 AM
