Results 1 to 7 of 7
Thread: leaky portafiller, Miss Silvia
    Aug 2006
    3
    how much pressure sould I use when locking in the portafiller on Miss Silvia?
    I have not used much force yet, lock in at about 90 deg.
    This is giving me an over flow and mixes water from the top of the portafoler with my espresso!
    Ok so this is all very new to me, but I dont want to break the machine in the first week.
    After reading many pages on the net and long hours spent looking over CS, I have now taken the plunge, with Miss Silvia and SB 480.
    Thankyou all for the great advise so far.
    Apr 2006
    4,126
    Re: leaky portafiller, Miss Silvia
    If its leaking, then you may well need to tighten it up more in the grouphead. Or you have too much fine coffee in your filter basket. There could be a few reasons for that but to answer your question about locking it in...
    I use on both the Silvia and the commercial machine enough force that the portafillers are tight and need a little effort to get them out again. Of course, my effort and tight are probably different to what a guys effort and tight might be. I couldnt really give you a precise pressure measurement, however.
    I wouldnt be too afraid of over tightening, I think that you would come to a point where it wont lock in against the rubber seal any harder anyway. And if youre worried about damaging anything, rubber seals are easy to come by and change at least.
    Aug 2006
    3
    Ok, ill give it a bit more of a push.
    as for the rest of the making a coffee thing, im in for a big learing curve.
    14,666
    extracto- if youre not getting the p/f to arounf the 5 oclock possie on this machine, its time for a new gasket. They do get old and brittle and they also expand and get full of gunk....I think theyre a couple of bucks!
    Go crazy! ;D- Good time also have a big clean when you drop the shower screen ;)
    2mcm
    May 2005
    1,964
    Quote Originally Posted by 2muchcoffeeman link=1155416495/0#3 date=1155427076
    2mcm
    I agree. Gaskets are cheap; Ive got a few spare ones sitting around for my silvia. Buy a few! But you certainly shouldnt have to replace your gasket in your first week ...
    Every now and then Ive had the same thing happen, and it can happen on ANY machine. As far as I can tell, like Chris said, it is a result of having a dirty group; grounds piling up on the gasket and mashing into it. One solution is to get a spare portafilter with a blind filter in it and do the portafilter wiggle after every few extractions (at home) or every 45 minutes or so (in a cafe). I dont have a spare portafilter at home, so I bought a pallo coffee tool and use that to keep the group clean. (You can get that from Veneziano and Coffee Hit, both of whom are site sponsors)
    Hope that helps,
    Luca
    Aug 2004
    2,312
    Information for all forum readers:
    a) Experience does show that Miss Silvia requires a good firm action on the group handle.
    b) The Pallo is a fancy group head brush with removable head (for when it wears out) and needle end for poking into steam nozzles to clear caked in milk. Nice enough.
    The *regular* group head brush doesnt have a removable head or needle end....but it is atleast $10.00 cheaper than the other, and you wont wear either of them out for years.
    My steam nozzle holes dont get caked up because we purge steam both before as well as after use but when we do find someone bringing in a blocked nozzle, we most often use a paper clip to do the business!
    All site sponsors should be carrying both of these items whether they are depicted on their websites or not, my own company included (see link below).
    Regardz,
    FC.
    Mar 2006
    703
    Hi extracto,
    Just in case, I have another second crack worth.
    I found the single basket is very touchy regarding how much coffee you put in and will easily leak over the sides if it is only slightly overfull, wheras the double basket is much more forgiving and you can fill it up and rarely does it leak if fitted tightly.
    For best brewing I think most avoid the single basket, instead use the double and waste some if you only want a single shot.
    Maybe this helps
    Regards
    Bullitt
  1. Leaky Silvia - Melbourne Repair?
    By digitalbugsy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th April 2013, 05:59 AM
  2. Silvia leaky steam arm, which part do I need?
    By muppet_man67 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th July 2011, 08:50 PM
  3. New silvia (2nd hand) old/leaky group seal
    By andrew in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th May 2008, 06:24 PM
  4. Leaky Silvia
    By TimA in forum Brewing Equipment (non-machine specific)
    Last Post: 29th January 2005, 11:12 AM
