Results 1 to 5 of 5
Thread: Brew Gasket
    Jun 2006
    754
    Brew Gasket
    Hey,
    When you backflush with the detergent stuff does the detergent detroy the gasket eventually?
    604
    Re: Brew Gasket
    Im not sure but gaskets need replacing regularly and its an easy job on most machines
    see:
    http://espressoparts.com/category/espressotutorials.e61groupmaintenance/
    yours may not be an E61 but its basically the same
    (BTW I assume you are using a machine that its ok to backflush on- some manufacturers even with 3 way valves dont recommend it)
    all the besst
    brett
    Mar 2006
    703
    Re: Brew Gasket
    Quote Originally Posted by Coffee Kid link=1155524432/0#0 date=1155524432
    Hey,
    Hi CoffeeKid,
    As I understand it, the life of the gasket has more to do with heatup and cool down cycles, and how long it is hot for during each cycle, and how clean it is kept in between.
    All machines with 3 way valves should be backflushed regularly, exact procedure depends on the particular machine, theres plenty of info available to help in that area.
    Regards
    Bullitt
    Jun 2006
    754
    Re: Brew Gasket
    I know the fact that if a machine has a 3 way valve it should be backflushed regulary, but i read on a site that when you take out the gasket and screen for a clean you cant put the gasket in the detergent or it will mark it permently or something :S
    604
    Re: Brew Gasket
    sounds odd- i thought only on E61 machines gasket and screen were one unit- on single boiler machines, you just unscrew the filter from under the group head and you wouldnt clean the gasket in that way- you would put in a blind filter and with the handle in the machine loosely, wriggle it about with the brew switch on
    try this page- it may help:
    http://www.wholelattelove.com/articles/backflushing_an_espresso_machine.cfm
    brett
  1. Brew Gasket Direction
    By FreshBlood in forum Brewing Equipment (non-machine specific)
    Last Post: 25th March 2011, 11:11 AM
  2. Replies: 0
    Last Post: 8th September 2009, 10:37 PM
  3. Replies: 0
    Last Post: 12th March 2009, 06:17 PM
  4. Gasket
    By Coffee_Kid in forum Brewing Equipment (non-machine specific)
    Last Post: 4th July 2006, 03:33 PM
