Results 1 to 2 of 2
Thread: Silvia + Sunbeam Burr Grinder (EM400)
    Aug 2006
    14
    Hi Everyone
    Whilst waiting for my Rocky to turn up I am using the above Sunbeam grinder with my new Silvia.
    Does anyone have any grind settings that they currently use with this combo? Mine is at about 11/12 but this seems slightly coarse to me
    604
    Re: Silvia + Sunbeam Burr Grinder (EM400)
    hi marxman- the answer is trial and error- every grinder even of the same brand is different- so are espresso machines
    even different blends and different daily humidities can make you adjust a notch either way- but its really not hard
    try finer if it seems too course
    25 sec of extraction should give you roughly 30 ml of espresso and nice crema- the trick is to not mind wasting a bit of coffee and not mind using a bit of time
    try to standardise on the amount of coffee in basket, time the extraction, mark a glass with 30 ml and change your settings a little at a time- if you keep these things constant it should be ok, but im not familiar with the fineness possible with that grinder- the silvia absolutely needs seriously good grinding and fresh beans
    brett
  1. Sunbeam EM0450 - new conical burr grinder
    By gupayami in forum Grinders
    Last Post: 31st August 2010, 08:17 PM
  2. Sunbeam EM0430 Burr Grinder
    By S.R.Tomlin in forum Grinders
    Last Post: 7th August 2006, 12:22 AM
