Results 1 to 2 of 2
Thread: Isomac Zaffiro
    Jun 2004
    138
    Isomac Zaffiro
    Anyone have a Isomac Zaffiro?
    Is $1600 too much for this machine?
    Is this machine easy to maintain and clean? (eg the shower screen, replacing rubber gasket, etc)
    Mar 2004
    200
    Re: Isomac Zaffiro
    no one else has replied so Ill have a bash...
    this is an e61 machine but it has no heat exchanger. This means it will not be as effective or efficient for steaming milk as a HX machine such as isomac tea or millenium.
    depends on what you normally drink, for straight shots the Zaffiro is highly desireable. Maintenance issues would be similar to any e61 as they all essentially use the same parts.
    I would probably see how much you could get a HX for, someone said the expobar office can be had for $1300. Isomac teas retail around $2k, or the one Id like but couldnt justify is an ECM Giotto premium which is closer to 2.5k.
    Once you get up there the Rancilio S24s becomes an option at 2200
  1. Isomac Zaffiro not heat up
    By Markus in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 9th April 2011, 05:31 PM
  2. Isomac Zaffiro
    By maso in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 8th October 2008, 04:44 PM
  3. Isomac Zaffiro
    By thad in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 20th August 2008, 03:21 PM
  4. isomac Zaffiro
    By Sullo in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st August 2007, 03:37 PM
