Results 1 to 5 of 5
Thread: Water Filters for plumbed in machines
    Jun 2005
    194
    Is anyone using this set up: http://www.coffeeparts.com/accessories/waterfilters.html
    I am looking around a bit (most likely to go with H2Only which Grant has - looks good) but am interested in any experience with the above as it seems very well priced.
    Nov 2004
    Sandringham NSW
    134
    Re: Water Filters for plumbed in machines
    Alec
    In the link to CP which filter were you thinking about?
    john
    Jun 2005
    194
    John, I am thinking about using the Omnipure SCL10, which I understand combines a carbon type filter with the Phosphate to reduce the hardness (I am in Perth so have to use a softner).
    I am thinking that the inline option with the SCL10 will do the trick (Ill run a T off the dishwasher tap under the sink) and it is quite a bit cheaper than a full inbuilt two stage filter with the little tap on the sink.
    I am still not clear on whether I need a sediment filter and if I did how many microns it should be. Some water shops have recommended between 1 and 4 mircons but I dont know if it is (a) necessary and (b) if too small will adversely affect water presure.
    I was also looking at the options available here: http://www.h2only.com.au/main.html
    The water shops are very helpful but they dont really know what I need to hook up to my coffee machine.
    Would you recommend anything in particular? I am just running a one group for low volume use at home.
    May 2005
    Perth
    1,332
    Alec:
    I dont think you can really get away from the full two cartridge system.
    If you do try to get away without a sediment filter it will most likely reduce the life of your carbon/phosphate cartridge.
    Imagine too if they are working on the water near you and you turn on beloved techno and get mud out of it!
    You would be very annoyed... :(
    Grant
    Jun 2005
    194
    Quote Originally Posted by wattgn link=1126066075/0#3 date=1126141121
    I dont think you can really get away from the full two cartridge system. *
    You would be very annoyed... *:(
    Probably a small price to pay, going two cartridge.
  1. Pure Water water filters
    By chrislng in forum General Coffee Related...
    Last Post: 18th December 2012, 06:34 PM
  2. Plumbed in machines in rented apartment. How hard to do?
    By tony8028 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st June 2010, 07:07 PM
  3. No plumbed filtered water
    By Doublee in forum General Coffee Related...
    Last Post: 28th April 2010, 10:10 AM
