Results 1 to 4 of 4
Thread: Nemox OPV adjustment
    604
    I recently bought my daughter a Nemox dellOpera.
    Im wondering about a few things:
    the grinder seems to need to be adjusted less than 2, because the espresso comes through at a rate of knots otherwise, blonding at about 15 secs.
    Now I compared the grinds I use on my two machines which require 1 step apart on the Cunill- they both like significantly coarser grinds to give the 30ml in 25 sec.
    Recently I did an OPV check on the botticelli and found it running at about 9 bars-
    question is, can the Nemox be adjusted- dont want to open it under warranty if Im just stuffing around? Its just that I wondered if its running over pressure.
    Also the Nemox seems to leak a bit around the filter if not push very hard to the right.
    Any help appreciated before I ring the supplier (The Beanery) which Id rather do after I get genuine in the field advice
    Brett
    Dec 2004
    Earth!
    15,778
    Re: Nemox OPV adjustment
    Quote Originally Posted by telemaster link=1160040611/0#0 date=1160040611
    Is the basket to full? Try with a bit less grounds in the basket and see if you still have to crank the portafilter on so hard.
    Java "Hhhmmm....Coffee!" phile
    Mar 2005
    2,165
    Hi Brett,
    Further to our email discussion regarding this, I dont think the OPV can be adjusted on the Imat / Nemox machines. I reckon the leaking would be the group gasket IMHO. No commercial plug, but I presume youre using a decent tamper for the Nemox (know youve got one for the other machines) that does the lot in one tamp rather than the built-in undersized thing? If not youll get uneven packing and premature blonding as the water will pick the path of least resistance. Ive found switching from my original tamper to a good fit brings improved consistency and a need for a coarser grind (which in my case is about 2.25 to 3.25, depending on the blend, but I understand the numbers are pretty meaningless as a means of comparison between machines)
    May 2005
    1,951
    Hi Brett,
    The non-adjustable OPV on the silvia can be tweaked: http://mysite.wanadoo-members.co.uk/m4tt5mith/SilviaPressureMod.html
    Note, though, that one really should check brew pressure before trying to do it. Also, that method of OPV adjustment can sometimes let a bit of water dribble out of the boiler.
    Luca
  1. Silvia OPV adjustment
    By Hildy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th May 2013, 02:43 PM
  2. Silvia OPV Adjustment
    By fancypants in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2010, 12:17 PM
  3. Replies: 0
    Last Post: 10th February 2008, 01:43 PM
  4. Cimbali Adjustment - on or off?
    By cjhfield in forum Grinders
    Last Post: 8th February 2007, 05:16 PM
