Results 1 to 4 of 4
Thread: Silvias with PID or other
    Aug 2005
    16
    Hi All
    A question to Silvia owners that have a PID or other Temp controller?
    What temp do you dial in and where is the temp probe locate ie top of boiler
    I am finding I am dialing up to 111c and still tasting quite smooth and wondering how high to go.
    Below 100c certainly can taste sour!
    What are your experiences
    Regards
    croweater
    Jul 2004
    106
    Re: Silvias with PID or other
    I tend to run mine set at 109-110 with the thermocouple mounted at the top where the stock thermostat sits.
    17,463
    Hi croweater,
    Yep, same as Mark. Didnt really have a choice, as there are no fixing points around the side of the Boiler anywhere. Its probably not a bad place to put it anyway since this is where the fresh water enters the Boiler and will therefore trigger the PID more quickly than if it was placed further away.
    My setpoint range ended up on 109-111 deg.C which results in a quite stable brew water temp of 93-94 deg.C measured using a t/c and suitable DMM with the t/c bead jammed between the side of the basket and the PF just under the lip area of the PF itself. Pretty well exactly the same as Marks setpoint range.
    If you really want to get technical, Sparky has performed a number of experiments monitoring the brew water temperature stability of a number of espresso machines, including the Silvia but he measures the Brew Water Temp with a t/c bead right up on top of the coffee puck so his measurements and settings would be more accurate. If you do a search through Sparkys posts re Silvias, Im sure youll find what youre looking for.
    In the end though, it just comes down to how the coffee tastes. By dialing-in the temp setpoint a degree or two at a time until you find the point at which the brew tastes great to you, will be the final arbiter. Once you identify this setpoint, just record it for future reference with the beans you have used, roast profile, age, etc etc and then you have a starting point to use as a datum for all future brews. Thats all I did with my Mokita and it just happened to settle in around the temp setpoint range I mentioned above.
    Just have to start cupping croweater.... better make sure its an early morning exercise on a Saturday though, otherwise youll be jumping around the place like a demented ferret ;) and thats not a good thing to be doing on a Sunday evening ;D
    Aug 2005
    16
    Thanks Mark & Mal
    I have to agree Mal there is only so much coffee you can drink in one day
    There is just so many variables
    And Golly all I want is a God shot every day ;D
    Regards
    Croweater
  1. 2nd vs brand new Silvias?
    By cyv in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 29th June 2009, 11:48 AM
  2. Why are Silvias Better???
    By Coffee2Di4 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th January 2009, 01:50 PM
  3. Silvias POD, not PID
    By robusto in forum General Coffee Related...
    Last Post: 2nd January 2007, 09:46 PM
