Results 1 to 15 of 15
Thread: Mokita Steaming Wand Upgrade.....
    17,463
    Hi All,
    Sorry to say :( that the Silvia Wand is not a direct swap replacement for the Mokitas original..... it is simply the wrong shape to work from the same take-off point as the original without some serious surgery, and Im not really up for that Im afraid.
    What I might do though, is chop the Mokita Wand above the Froth Enhancer Boss and silver solder the bottom section of the Silvia Wand to it, so all is not lost ;D. Will report back when Ive done this with piccies, etc.....
    Jul 2005
    255
    Re: Mokita Steaming Wand Upgrade.....
    Bummer that the joints dont match, Mal.
    I was hoping to do a similar thing with my Nemox Fenice. If I can remember properly, the Fenice and the Mokita have different wands. Ill post here once Im back home in Aus in a couple of weeks time.
    Mar 2005
    30
    Its a bummer about Plan A Mal.
    Fingers crossed for Plan B
    Luke
    17,463
    Hi Guys,
    Re the Fenice.... from memory, I think the wand take-off point is still the same, even though the wand itself is slightly different. Its this that makes the swap impractical as the bends in the Silvia Wand just do not match up with the height the Mokitas wand starts from, and the hole in the panel for the Wand to exit through. Will be interested to hear what you think once you get back though rice.
    Will keep yall posted re Plan B though,
    May 2005
    1,992
    Before yall go chopping up your Mokita steam wands, you might want to try to get a hold of the fitting from the overpriced thermoblock that Breville is selling; you know; the stainless steel $25 krups? It looks completely exchangeable with the Silvia steam wand, so it might fit, but it has a swivelling ball joint and is angled like the giotto wand! Yes, it has a froth aider on it, but this slides right off to reveal a wand thats basically Silvias, but better.
    Luca
    Jul 2005
    255
    Luca, thanks for reminding me about that Breville wand (again), completely forgotten about it.
    (all this wand talk...wish a wizardly shazam would change the steam arm)
    17,463
    Quote Originally Posted by luca link=1135784235/0#4 date=1135853076
    Luca
    Hi Luca,
    Any pictures or links to same at all? Definitely sounds interesting :-/
    May 2005
    1,992
    Sorry, Mal, really shouldve googled it before:
    Breville 800 class: http://www.breville.com.au/products_detail.asp?prod=286
    Could only see small pictures online, but you can see that the steam wand has a ball joint. The froth aider is just a metal tube that slides over the rubber grab tab; quite a clever design, actually. You can just slide it right off and be left with a wand that looks like a silvia wand, but bent outwards - awesome! The nut LOOKS exactly the same as the Silvia fitting.
    This machine is a real winner, too. For $400, you get:
    800 Class™ Espresso Machine
    800ES
    From its heavy-duty housing and professional grade functionality through to its superior and easy operation, the 800ES is designed for the true coffee connoisseur.
    Features
    • 15 bar thermoblock pump system
    • Advanced dual wall crema system
    • Pre brew function
    • Auto purge function
    • Commercial die cast design
    • 2.2 litre easy front removable water tank
    • Additional hot water function
    • Commercial swivel steam wand
    • Extra large cup warming plate
    • 1 litre capacity drip tray
    • Storage draw
    • Accessories - stainless steel frothing jug, tamping spoon and cleaning tool
    • 2 year warranty
    Well, damn, Ill get Andrew to cancel the order for the Synesso ... ;P
    Krups in fancy pants!
    Luca
    17,463
    Thank you kindly Luca,
    Youre right.... it looks like a very purposeful steaming wand compared to the Mokitas. Ill get in touch with Breville and see if I can buy a Wand Kit from them. Thanks again :),
    17,463
    Hi again All,
    Hope everyone had a terrific New Year celebration.... bound to be some good stories from some members who may have witnessed unforeseen events ;D
    Anyway, so that this thread doesnt become a total loss, Ive penned out an Electrical Schematic for my Mokita as part of the effort to tidy up the wiring a bit. It includes detail on my particular PID installation but you can ignore this for the most part, and just substitute the "Brew T/Stat" for the "SSR Power Contact" where it appears near the top of the drawing.
    The link to download the PDF file is here...http://tinyurl.com/eswv8.
    Hope this is of some help to those Mokita/Nemox Fenice/Quaha owners out there who may need it for future repairs or mods, etc.
    In either case, ALL internal wiring work can only be undertaken with the unit UNplugged from the Mains Power. Youll also have to make sure that you have the work completed, or at the very least inspected by a qualified and licensed Electrician or Electrical Engineer, before plugging it back into the mains. 240 VOLTS CAN KILL!! :o
    For anyone who is interested, I have a swag of photos of the disassembly and re-assembly of the Mokita too. Just let me know if youd like copies. :)
    Notwithstanding the cautionary warning, once again, I hope it proves helpful. All the best,
    Jan 2005
    338
    Hey Luca - Ive used one of those 800 class brevilles.
    IMHO they suck.
    The best of the worst....
    There is no difference between steam warm up, and steam on. The great design is that you put the "Froth enhancer" in the milk and turn a single switch for steam... then it comes up to speed while the wand is on.... so you get a pittiful amount of pressure that builds up to a pretty bad amount at full crank (but by then youve probably gone well over 70 degrees anyhow!)
    Jul 2005
    255
    Thanks Mal, Im sure the schematic will come useful to me and others around these parts. Us owners of the Quaha Junior/ Imat Mokita/ Nemox Fenice et al seem to be a rare breed compared to the Silvia mobsters. Greg Pullman has some useful info on his site http://www.coffeetamper.com.au/imat/ Ive sent you a PM with my email address, would you be able to forward the images of the disassembly to me?
    p.s. If you are using PS (Photoshop), you can automate the signature insertion into the images.
    http://www.myjanee.com/tuts/brush/cbrush7.htm
    re: Breville 800
    I think (hope?!?) Luca was mocking the 800 class. Itd be funny to watch him try to talk someone out of a Synesso for a Breville. Now thats even better than selling ice to an eskimo! :D
    Feb 2005
    441
    Luca? Joking?
    I heard he was thinking of ditching the silvia for that breville baby.
    14,665
    Sorry guys- have tried the breville wand and its a no go.....the attaching nut needs a complete redesign....
    17,463
    Quote Originally Posted by rice link=1135784235/0#11 date=1136363857
    No worries Mate,
    Will attach and send in the next couple of days :)
    Afraid Im a Corel user from waaayyy back, but thanks for the info ;)
    re: Breville 800
    I think (hope?!?) Luca was mocking the 800 class. Itd be funny to watch him try to talk someone out of a Synesso for a Breville. Now thats even better than selling ice to an Eskimo! :D
    Im sure he was.... bugger about the steam wand though :( Thanks for that info Chris.
  1. La Pavoni Steaming wand attachment
    By Planeray in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd December 2011, 09:30 AM
  2. Steaming Wand
    By Coffee_Kid in forum Brewing Equipment (non-machine specific)
    Last Post: 1st July 2006, 09:53 PM
  3. Replace Imat Mokita Steam Wand
    By Dimal in forum Brewing Equipment (non-machine specific)
    Last Post: 12th November 2004, 03:12 PM
