Results 1 to 4 of 4
Thread: Broken Minore
    Sep 2005
    20
    Broken Minore
    Hey guys,
    My Minore (Brewtus ) In the midst of a series of shots, the temp display went off totally and hasnt come back on. Steam element light still works, pump still pumps, but the water coming through the group is not being heated.
    Plenty of water in the tank...
    Any ideas?
    Ill take back to tomorrow, and just before the weekend Crap!!!
    Mark
    Aug 2005
    1,530
    Re: Broken Minore
    If you can open it up, you might want to have a peek to see if anythings come loose. It might be as simple as that. Can you tell if the temp is reasonably stable? If so, then its just an issue with the display.
    Sep 2005
    20
    Re: Broken Minore
    Everything looks ok inside nothing loose. the brew boiler isnt heating up i can run my hand under the runing group head.
    I think the water is warm because the water comes from the steam boiler (which is working), through the heat exchanger into the brew boiler hot mixing with the cooling brew water.
    Think the Temp control is broken.
    Mark
    17,547
    Re: Broken Minore
    Hi Mark,
    Might be just an internal fuse for the controller itself. If its still under warranty though, I wouldnt touch anything, as you say, better to take it back to the retailer you bought it from,
  1. Help - my Expobar Minore is broken!!
    By needmycoffee in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th January 2008, 08:15 AM
  2. My plunger is broken
    By Lovey in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd July 2007, 08:42 PM
