Results 1 to 8 of 8
Thread: gaggia cubika worth 250 bucks???
    Feb 2006
    313
    Hi guys, I saw this machine reduced to this price from 350 at harris Scarff and wondered whether it would be worth my while getting it. The saeco inacnto I have leaves me nothing to experiment with as far as grind and tamping and what not. I cant afford miss silvia. Is this gunna do the trick? THe PF handle is alloy and not too heavy but very wide. It says its 15 bars of pressure - does that mean its a thermpump?
    So - what do you reckon? :-X
    14,666
    Re: gaggia cubika worth 250 bucks???
    Quote Originally Posted by rayzurhed link=1143431809/0#0 date=1143431808
    As per usual, its a case of you gets what you pays for....At least it has a boiler though I suspect it may be aluminium- be careful with water to avoid corrosion/scale. Non standard pf means its hard to play with basket size etc. As an entry level machine, when on a budget- I suppose so. Have a look on CG- there are lots of reviews of it....
    2mcm
    May 2005
    Sydney Oz
    503
    I thought most Gaggias had an aluminium boiler, but could be wrong. Why dont you space bank that $250 towards a Silvia, then you only have $500 or so left to save! Yeah I know - easier said than done ;)
    17,406
    Ummm,
    Theres one for sale here http://coffeesnobs.com.au/YaBB.pl?num=1143288132 a lot cheaper than that ;),
    Feb 2006
    313
    Thanks guys. CG was a good source of info.
    I checked out the silvia for sale here and :(
    havent got the dosh as yet.
    Maybe I will hold off- keep learning- and dream a bit.
    Actually dreams make good espresso.
    Feb 2005
    3,056
    Is it worth it? If youre not satisfied with your present machine, chances are you wont be satisfied with this low-end Gaggia with the lightweight aluminium portafilter and corrosion-prone aluminium boiler either.
    Sorry, but I must add my voice to the chorus of save up for something better like a Silvia.
    Robusto
    Jun 2004
    283
    wow, that mystery post linked above has gone AWOL.... or am I on the outer now?
    An Error Has Occurred!
    You are not allowed to access this section.
    Dec 2004
    Earth!
    16,045
    Quote Originally Posted by poundy link=1143431809/0#6 date=1143508807
    It looks like the linked post has been removed by a mod/admin under the new For Sale posting rules.
    Java "Which way did it go, which way did it go." phile
  1. problems with Gaggia Cubika.....
    By thegeneral74 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 20th August 2009, 10:24 AM
  2. Gaggia cubika
    By derrilex in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 14th August 2009, 05:56 PM
  3. Gaggia Cubika, 10 months old
    By nicholasm in forum SOLD
    Last Post: 29th September 2007, 09:05 AM
