Results 1 to 8 of 8
Thread: Pressure regulator?
    Feb 2006
    459
    Pressure regulator?
    I asked in another thread, but figured Id stop hijacking that and start a new topic...
    I reckon I could find a spare pressure regulator lying around at my work, and a couple of tube fittings. I reckon it would be quite easy to plumb it in to my machine. It would act to limit the pressure entering the *cough*thermoblock*cough* to a defined (but adjustable) level.
    Does anyone think this would be a good or bad thing to do? I am sure that such a setup would improve my singles, which presently are too hard to slow down.
    May 2005
    1,958
    Re: Pressure regulator?
    Hrmmm ... sounds good. Two questions, though:
    (a) How are you going to measure the pressure?
    (b) Will it change the temperature of the water coming out of the thermoblock?
    Luca
    Feb 2006
    459
    a) pre-set the regulator before installation (I have calibrated gauges at work). The adjuster knob can be locked in position. There might be a small dynamic pressure loss across the thermoblock, but I dont think its significant.
    b) It would be installed before the thermoblock, so I cant see how it could...
    admittedly, the regs we have we normally use for gas, but Im sure they could handle such low water flow rates... Theres a slight drop off in pressure as flow rate increases from zero, but its pretty small...
    worst case, I can always remove it and join the lines back together with a union...
    Apr 2005
    1,176
    An interesting idea. Im not sure how the membrane will respond to a liquid, which has a density about 1000 times greater than a gas (and hence considerably more momentum at the flow rate youll need), but if you have one kicking around it might be worth a go. The other option is to use the standard overpressure expansion valve. Coffeeparts sell them for about $16. They are the ones that come with Fluid-o-tech pumps and they work well. However, youll need a pressure gauge somewhere in the line to measure the set point pressure. Thats no real problem as you can get damped pressure gauges for about $12 around the place. A few extra brass connections and youre away... Then you can PID control the temperature of the thermoblock....
    The thermoblock will have no problem with a lower regulated pressure, as it is only flow rate dependent, so once you get within the standard espresso flow rates, it should be transparent to your system. Lowering the pressure to 8-9 bar makes a huge difference in the crema and mouthfeel of the shots. Its well worth trying to get it sorted.
    Feb 2006
    459
    The temp regulation is something electronic already (thermistor to a PCB, not a termostat). Im curious to hook up a light to it so I can see what the switching cycle is...
    mattyj says theyre temp adjustable on the PCB too (I spot a potentiometer there), so I might tweak that one if I get inspired. (Can borrow some thermocouple gauges from work.)
    Feb 2005
    441
    Wow, this is everything I once wanted to do to my sunbeam and more!
    the 6-million-dollar sunbeam!
    Feb 2006
    459
    :D I checked the Norgren catalog for specs, the R07 I wanted to try is rated only for air only :(
    Theres an R06 which is suitable for water, might work... I saw one for 4 quid in the UK! http://www.engsurplus.btinternet.co.uk/pneumatics.htm
    Apr 2005
    1,176
    There are plenty of fuel pump pressure regulators on ebay... Im not sure if theyll got to 10 bar though.
    If you get a 240 V neon bezel and connect it across the element terminals, youll be able to see the on/off period. It would be interesting to see what it does during a shot, as thats when youll need the element to really work.
  1. BZ40 - group head pressure not stable when adding water pressure limiter
    By pup26 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th March 2012, 08:24 PM
  2. Boiler pressure - small high pressure boilers
    By dane5431 in forum General Coffee Related...
    Last Post: 6th May 2011, 04:16 PM
  3. Pressure regulator
    By Ralph in forum Brewing Equipment (non-machine specific)
    Last Post: 9th October 2007, 10:55 PM
