Results 1 to 19 of 19
Thread: Need some advice
    Aug 2006
    46
    Need some advice
    I am new to coffeesnobs and after reading some of the topics here its time to take the plunge into the big wide world of espress.This is where you guys come in. I am thinking about buying a rancillo silvia and rocky combo as it seems to be what everyone here likes, but i am unsure wether it is really what will best suit my needs. What i am after is a semi auto machine that is easy to use and produces consistent coffe (sick of drinking the rubbish that most coffee shops up here try and pass off as coffee). After reading the reviews here it seems that the silvia may be a bit fiddly to achieve consistent coffee, is this the case? The other option i have been thinking about is the Imat mokita, what do you guys think would suit my needs better. I have a budget of around $1200 might be able to stretch a little further if needed. My fav style of coffee is a Latte with a double shot of espresso and i am the only coffee drinker in the house but i usually drink approx 3-4 cups at home per day and another 2-3 at work. Can you also please point me in the direction of a reputable dealer in brisbane
    thankyou all
    604
    Re: Need some advice
    silvia lovely ecm botticelli has similar features but slightly larger boiler, more stable temp (no need to surf) and temp gauge
    i love mine- talkcoffee may do deals also barazi- there may be an ex demo one still on the for sale section from barazi for 750- usually approx 1000
    all the best
    brett
    Aug 2006
    46
    thanks brett,
    ive ordered a silvia rocky combo from chris 2mcm now cant wait till it arrives
    mattm
    604
    Quote Originally Posted by mattm link=1154940650/0#2 date=1156071925
    thanks brett,
    mattm
    mmm... nectar of the gods- youll do fine!
    brett
    Aug 2006
    46
    only ordered on thursday but already wishing it was here!!! dont think i can wait much longer.
    mattm
    14,666
    Be patient Matt- should be with you tomorrow!
    regards
    10,496
    I was the same waiting for my machines.
    Hang in there just a little longer.
    Aug 2006
    46
    thanks chris for all your help really looking forward to tomorrow
    mattm
    Feb 2005
    3,049
    .....So what happened, Mattm?
    --Robusto
    Aug 2006
    46
    robusto,
    having a ball experimenting with new silvia and rocky, nearly had it a week now and its the best thing i have ever bought(and ive bought some pretty good gear in the past)
    still experimenting with coffee,grind etc but making pretty good coffee so far
    not good enough to drink as a short black varies between bitter and sour and trying the temp surf thing but havnt found much difference doing this, probably due to inconsistent dosing tamping.
    however add some milk and presto best coffee had in a long time(i may be alittle biased) except for the shots i had at merlo last friday
    thanks for your interest and ill keep you all updated
    mattm
    Feb 2005
    3,049
    Youre on the way --- the journey of a million miles begins with a few beans.
    Try to change one variable at a time. Get that right, then move on to something else which may still need improvement.
    You want about 17 to 20 grams for a nice 60 ml espresso.
    An electronic scale will assist you dosing the correct amount.
    Then, get a bathroom scale, put your loaded portafilter on to that, and tamp down to the 2 stone mark.
    Youll now have the correct dose and correct tamp.
    See how long it takes for a 25" extraction.
    Too long? Grind coarser.
    Gushes out? A finer grind is in order.
    Having got those two variables right, temperature is next.
    I use a PID, but if you brew around 50 seconds from when the Silvia brew light comes on, youre in the ball park. I think 40 seconds is too cold.
    All this should conspire towards a very acceptable espresso---providing, of course, you start with the right raw material: fresh beans roasted right.
    ---Robusto
    Aug 2006
    46
    robusto,
    i think i may have stumbled across part of my problem......the cheap plastic tampa that comes with the silvia.
    after a close inspection of the puck after a shot tonight ive discovered what looks like to me is the problem!!! It looks like the outside 3mm or so of the puck is where most of my brew water is going through as it is a completely different colour to the rest of the puck.
    i have been using the standard tampa on the bathroom scales and tamping to about 15 kilos
    do you think this could be why my shots are bitter?
    im going to make a new tampa tomorrow at work(one of the benefits of being a fitter and turner) that fits the baskets a bit better and try it tomorrow night
    ive run out of coffee beans so am planning a trip back to merlo in the morning to by some more(made the mistake of only buying 2* 500 g bags last week and they have already gone(probably why i cant sleep at night)
    Im also expecting a delivery from coffe parts tomorrow with the larger pf basket and from what ive read this will probably help as well
    mattm
    14,666
    Absolutely Matt- the plakky tampers are a complete waste o time....Id bet that with a poor tamper and the smaller basket, you are getting chanelling....This should disappear with the new tamper and larger baskets.
    NB- youll probably need to back your rocky off a notch or two to get that perfect pour....let your palate be the guide!
    2mcm
    Aug 2006
    46
    thanks chris,
    i ordered that gear from coffe-parts yesterday and they said it should arrive tomorrow, first job will be to give it a good clean then ill try the new basket and tamper and coffee.
    really love the silvia and thanks for all your help over the past few weeks its been very much appreciated
    ill keep you posted how things are going
    ps got in trouble from the misses this morning for making a coffee at 4am, but made up for it by making her a hot chocky tonight(gotta love that khali hot chocolate from coffee hit
    mattm
    Aug 2006
    46
    could somone please tell me how i know if im getting channelling. Will i be able to see small tracks/grooves/holes etc or will the puck have different colours through it?
    My new goodies arrived from coffeeparts today so i removed the showerscreen and soaked it and the pf and baskets in the espresso cleaner, then reassembled and backflushed using the newly aquired blind filter......yuck how does a machine get so dirty inside after just one week?
    Then the biggest surprise!!!! using the larger porter filter basket p/n mar1-521994 from coffee parts made a coffee, took 47 secs from turn on to 60ml, set grinder 1 notch coarser 35 secs from start to 60ml, one notch coarser again 28 secs from start to 60mls in 2 shot glasses(30 in each)
    biggest surprise was that during the pour only had about 3mm dark liquid in bottom and a nice treacle coloured crema making up the rest of the 30 ml, and after approx 1 min still had 6-7 mm of crema on top so i took the taste test straight from the shot glass.....
    mmmmm first shot ive made on silvia that ive been able to drink fully as an espresso, still a bit bitter/sour not sure which, hard to tell but definately drinkable
    pour starts off really dark almost like the colour of dark chocolate then slows down to an almost drip after about 5-6 secs stays dripping for another3-5 secs then steadied out to a slow pour of a trecle type colour for the remainder. No sign of blonding switched off after 30 secs and had about 28ml in one glass and 32-33 in the other.
    drank one shot straight, turned the other into a latte while frothing milk for the baby chinos and hot choccies and this latte was excellent, best yet even milk is getting pretty good can support a teaspoon verticle in a baby chino
    mattm
    ps chris ive got to work all weekend so ill call you on monday and talk
    Jul 2004
    2,134
    Quote Originally Posted by mattm link=1154940650/0#14 date=1157103742
    Matt,
    When you take the portafilter out after your shot and look at the puck (whilst still in place), if you see any small divots, usually around the edge, that is a sign of channeling.
    If the top of the puck looks uniform, then your tamp has most likely been a good one.
    Hope that makes sense.
    Brett.
    Jun 2006
    754
    Does crack mean channeling as well? or holes?
    14,666
    Quote Originally Posted by Coffee Kid link=1154940650/15#16 date=1157115051
    Cracking, pitting or holes are all similar problems caused most frequently by poor (insufficient) dose (and sometimes poor tamp). If your coffee pucks are wet and or spongy, you are probably underdosing and this will often lead to channeling. This will usually lead to sour espresso (tasted towards the tip of the tongue)...
    2mcm
    Aug 2006
    46
    hi all,
    just thought id give you all an update on how things are going.
    i think i may have found out why my shots were bitter...temp of shot too cold?
    after reading some old threads here i found one re temp surfing where the author actually waited for the brew light went off and then turned the steam switch on for 10 secs then pulled the shot with the steam switch still on, well i tried this and my shots seem to be a lot more drinkable and a lot darker in colour but dont seem to be burnt .
    Also been experimenting with grind and tamp settings but still cant get 60ml in 25-30 secs but think my problem is uneven dosing. guess ill have to keep trying.
    On the subject of milk frothing managed my first almost latte art, i thought it looked alright but the misses laughed at it, seems like i was trying to stretch the milk to far previously, also bought a thermometer which has fixed my problem of coffee being cold(was only getting to about 50c ) now much better at 65.
    Ordered naked pfilter after reading some cool info about them and the excellent pickies this should help me identify some problems
    mattm
    mattm
  1. New, need advice
    By Jess in forum General Coffee Related...
    Last Post: 3rd May 2009, 08:59 AM
  2. some advice please!
    By damian1 in forum Blending Room
    Last Post: 20th November 2008, 08:47 AM
  3. Advice
    By browny in forum General Coffee Related...
    Last Post: 11th August 2007, 09:26 PM
  4. Any advice ... ?
    By Dr.GTD in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 6th May 2005, 06:08 AM
