Results 1 to 7 of 7
Thread: Newbie - Silvia Coffee Problems
    Aug 2006
    14
    Hi Everyone
    I seem to be having very inconsistent results with my Siliva. Ill go through the process and someone can hopefully let me know what Im doing wrong:
    1) Grind the beans at approximately 11 on my Sunbeam 4800 burr grinder directly into filter basket.
    2) Level off with back of knife
    3) Grind more coffee into filter basket.
    4) Tamp (with budget Silvia tamper whilst wating for my pullman tamper to arrive!!!) coffee down to line in filter basket. I do tamp quite hard.
    5) Attach filter to machine and turn pump on.
    6) The coffee usually takes about 8 seconds to start puring and is a very slow drip or trickle. Then it takes about 40 seconds for 30 mls and it has very limited to no crema.
    Im assuming that I am either:
    - tamping too hard;
    - or grinding to fine.
    What are everyones thoughts?
    Apr 2005
    234
    Re: Newbie - Silvia Coffee Problems
    Hi,
    Assuming your Silvia is is good working order, you are correct in suspecting the grind or tamp...I think you will get better results with a decent tamper, but in the meantime, try:
    backing off on your tamp pressure a bit and see if that improves the flow and crema...if not,
    try making your grind a degree or two coarser, and try the same...Im not sure how the numbers on your grinder relate to mine, but you can certainly experiment with these two variables...
    Oh, and make sure your coffee is fresh too.....:)
    Aug 2006
    14
    Coffee is definately fresh as it was from my first roasted batch of Sumatran beans i received in the starter pack!!! They smelled fantastic this morning!!
    Senior Member Lovey's Avatar
    Apr 2005
    South Coast NSW
    851
    Another observation/suggestion,
    It looks like youre over-dosing the basket, try packing a bit less into the basket and see how you go.
    When Im grinding into the basket and I get to about 3/4 full, I give the portafilter a tap on the counter top to settle the grounds. I then continue grinding so that I get a slight mound in the basket, I then level off with the back of a knife and then tamp.
    Once you get your dosing consistent, then you can make adjustments to the grind to adjust the pour time.
    Hope this helps.
    Jul 2005
    131
    Marxman,
    You havenít said how long your machine was running or if you have been temp. surfing. * My experience was that until the temp. thing is sorted results will be very inconsistent.
    Randy Glass has a blog and how to pages on just about everything to do with Silvia.
    http://www.espressomyespresso.com/
    Iím certain that you will find your solution here.
    Good luck
    Billi * *
    Nov 2004
    Augustine Heights QLD
    302
    Marmax,
    I agree with what the other have said and suggested. Sounds like youve packed the PF too tight and are choking Silvia. To confirm this as the pump struggles to get a shot out, lift up the water tank lid and see if there is water being returned through the shorter of the two plastic water tubes. The long one is the water pick up, the shorter is the head bypass.
    Ill assume your pucks are knocking out like biscuits. This is what your after, combined with fresh beans, then really the only other variables are the temperature cycle (when to pull the shot) the grind size and how to pack the PF. Ill also assume youre not using the single basket (its a pain when youre starting out).
    If you grind too course, youll have to tamp harder, grind to fine and youll have to pack and tamp lighter. Bear in mind that by over filling the PF, when you lock it into position, the force you apply to the PF to get it in position is further compacting the grinds. Then when you pump water through it, the grinds are going to swell as the absorb the water. All this will choke the Silvia.
    Back off the tamp, try testing the pressure on the bathroom scales. If youre happy its not excessive, settle the grind in the PF by tapping a few times, then top up and tamp. You may have to grind a little more course.
    Any snobs near by to visit?
    Good Luck
    Boris ;)
    Mar 2006
    703
    Hi Marxman,
    sorry its a bit late,
    But I had a time where it was taking about 8 seconds or more for water to come through, and two of the factors that can affect this are;
    - Not refilling boiler after last use, especially if you were steaming milk, or pulled a couple of shots, AND,
    - the steam wand will drip a bit while youre waiting for Silvia to stabilise, so I make sure the steam kknob is firmly OFF
    If either of these two possibilities done make any difference than next thing I would try is to change grind setting by one notch, aiming for approx 30 mls in about 25-30 seconds.
  1. Newbie to Gaggia Classic - brewing problems
    By KimDD in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th September 2011, 06:33 AM
  2. Silvia first day problems
    By RJM in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th June 2011, 07:11 AM
  3. Silvia Problems
    By nanga1972 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 7th April 2011, 07:26 AM
  4. Silvia Problems
    By JR in forum Brewing Equipment (non-machine specific)
    Last Post: 18th January 2005, 08:16 AM
