Results 1 to 4 of 4
Thread: Brasilia Lady Temps
    Jun 2006
    59
    Brasilia Lady Temps
    Hey,
    Im trying to get the right temp for my machine at the moment, but I have too many other factors that are stuffing things up, like bad tamp/tamping etc.,
    But when I flush as soon as the temp light goes out heaps of steam comes out, which I take as meaning its too hot. Would I be correct? If I flush until the steam stops will that be the correct temp? Im sure the answer is already posted here somewhere, but I havent been able to find it...
    After I get my new Pullman tamper [smiley=happy.gif] I should have a better chance of experimenting with temps.
    Rob
    Apr 2005
    1,176
    Re: Brasilia Lady Temps
    In general, once the water stops flashing to steam you are at or below the 100 C mark. You want to be in the 88-95 C range, so you generally flush a bit longer. Details vary from machine to machine, but Ill flush about 200 ml with my machine before making a shot.
    Mark.
    604
    Hi Frad, not sure if the Lady is like my ECM botticelli, large single boiler?
    If so its like Sparky said. When my boiler light goes out I flush for about 5 sec to get the hissing, bubbling boiling water out and then about 2 sec longer- about right for my machine- 92/93 C
    Brett
    Jun 2006
    59
    Cheers for that fellas. Ill have a play around with that and see how I go.
    I already got a better extraction after 1 go.
  1. Brasilia lady
    By latte_boy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th May 2012, 01:09 PM
  2. Brasilia Lady
    By latte_boy in forum Brewing Equipment (non-machine specific)
    Last Post: 30th June 2008, 11:40 PM
  3. Brasilia lady
    Last Post: 8th May 2008, 10:13 PM
