Results 1 to 2 of 2
Thread: Silvia - Idle Boiler Pressure
    Dec 2004
    30
    The only dumb question is the one you don’t ask – agreed!
    Should the Silvia have any `built up` steam pressure with the machine being left on and idle for some time – and why is it not consistent?
    If the Silvia has been left on and idle for several hours (or longer) – and with the heating lamp off - if I open the steam knob I get a large release of pressure through the steam want. i.e. 20 - 30 seconds of wet steam
    Other times I get nothing – not even a whisper.
    Is this normal?
    Thanks,
    Col.
    Aug 2004
    2,312
    Re: Silvia - Idle Boiler Pressure
    Yes, it is normal.
    These machines like all domestics are controlled by thermostats rather than by pressurestats. Effectively in terms of pressure, you get whatever you get when the machine is left on for extended periods, and in practice yes, you get a "slight" build up of pressure which is that which we all purge by temp surfiing the group before placing the group handle to make coffee.
    Just because the machine is thermostatically controlled and can be left on all day, doesnt mean that leaving the machine on all day is what the designers had in mind.
    Basically, its a fact of life and nothing to be concerned about.
    Regardez,
    FC.
  1. Boiler pressure problem
    By FineGrind in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th December 2012, 02:06 PM
  2. Cimbali Junior D/1 boiler pressure
    By valimar in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th October 2012, 09:54 AM
  3. Boiler Pressure
    By specialpants in forum Brewing Equipment (non-machine specific)
    Last Post: 1st December 2011, 07:01 PM
  4. Boiler pressure - small high pressure boilers
    By dane5431 in forum General Coffee Related...
    Last Post: 6th May 2011, 04:16 PM
  5. Isomac Tea II Boiler Pressure
    By scollops in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th June 2010, 11:54 AM
