Results 1 to 12 of 12
Thread: Leaving PF locked in grouphead for extended period
    May 2007
    708
    Ive always wondered if it was ok to leave the PF locked in (not tight) the grouphead for any extended period of time ie. overnight to warm up together with the machine set on a timer? Given PFs are quite heavy with some brass in them, would leaving them in the group cause increased wear or stress on the group section itself?
    Mar 2008
    554
    Re: Leaving PF locked in grouphead for extended pe
    I have always left the PF in the brewhead when my machines were not in use. Mainly because, first thing in the morning, it is so hard to remember to lock it in place while fighting the morning, mental fog. Never caused any problems so far as I can tell. As you said, I just lightly tighten it until the pressure of the gasket stops its motion— not locked fully in place as if to brew— that saves the brewhead gasket for unnecessary compression. .
    Apr 2007
    1,687
    Quote Originally Posted by Randy G. link=1217597876/0#1 date=1217599497
    I have always left the PF in the brewhead when my machines were not in use. Mainly because, first thing in the morning, it is so hard to remember to lock it in place while fighting the morning, mental fog. Never caused any problems so far as I can tell. *As you said, I just lightly tighten it until the pressure of the gasket stops its motion— not locked fully in place as if to brew— that saves the brewhead gasket for unnecessary compression. .
    Ditto!
    sdg
    sdg is offline
    Mar 2008
    368
    I sure hope not, because leaving the PF loosely in the group to keep it toasty is exactly what I do, as well :-/
    Though I cant see how it could damage anything, just to have it sitting there.
    May 2007
    Perth, Western Australia
    3,152
    Yes, loosely.......................sometimes I bump it and it falls down and scares the c....p out of me!!!
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by greenman link=1217597876/0#4 date=1217632214
    What he said...
    Apr 2008
    Brisbane
    5,113
    I don’t leave it in
    Due partly to safety with a handle sticking out to bump into when walking past as my machine is positioned on the outer edge of the bench
    For this reason I leave both my Porta Filters placed on top of the cup warmer
    I run a water shot through the PF to warm it to same temp before any coffee
    14,665
    Quote Originally Posted by Koffee Kosmo link=1217597876/0#6 date=1217643034
    I don’t leave it in
    I disagree. Keep it in, loosely locked, clean, warm and dry.
    Apr 2008
    Brisbane
    5,113
    I hit my arm on it every time I walk to use the kitchen sink if the PF is left in the group head
    And I can do without a corked arm Chris
    I don’t disagree with others it’s a safety thing for my situation
    Feb 2005
    441
    Ive actually started leaving mine out lately, rather than locked in.
    Partly because my basket sticks to the gasket if I leave it in, so when I take the pf out, the basket stays stuck in and its a PITA to get out, especially when its hot.
    And partly because I figure that if I have to run cooling flushes, I might as well kill two birds with one stone - run the cooling flush with the pf in place to get it hot.
    Ive noticed no difference in the cup, and I figure thats the most important thing.
    10,496
    Quote Originally Posted by AngerManagement link=1217597876/0#5 date=1217635482
    What he said... *
    Ditto.
    Mar 2006
    703
    Quote Originally Posted by mattyj link=1217597876/0#9 date=1217678662
    I had similar problems a while ago,...basket sticking to gasket, that is,...
    was starting to lock the pf in too tight, it wont stick to the basket if the pf is only loosely in the head. Having said that. mostly it is out when machine is off, I put it in as I turn it on.
    Bullitt
  1. Resting period post roasting
    By Bubbacullen1 in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 23rd April 2010, 12:18 PM
  2. Pullman Tamper Delivery Period
    By ahxiongko in forum Brewing Equipment (non-machine specific)
    Last Post: 20th May 2008, 09:29 PM
  3. Locked thread
    By JavaB in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th April 2007, 09:08 AM
