Results 1 to 3 of 3
Thread: Tamper for Krups non-pres baskets...
    May 2008
    35
    I know, I know I could send one off to get a custom tamper but given I probably will have a machine with 58mm baskets soon enough I cant really justify spending >$100 now and then another $100+ later...
    If someone could suggest an off-the-shelf tamper than fits the Krups non pressurised baskets that people (myself included) are using in the lower end Sunbeam machines that would be most appreciated. The tamper I have is not a great fit and I think is starting to become the limitation on quality .. which is good I guess because I think its no longer me :)
    Thanks, any help is much appreciated!!
    Mar 2005
    2,165
    Re: Tamper for Krups non-pres baskets...
    Theyre not all the same unfortunately, as weve found over time. But a 51mm is about the closest youll be able to get - if you can find one that is, its not a very common size in aftermarket tampers as there is are relatively few below 55mm and theres no standard.
    Alternatively, one tamper manufacturer I know of (I know them quite well actually... ;)) will give you a trade-in on your old tamper base when the time comes to upgrade so you can to a point have your cake and eat it.
    Nov 2007
    160
    Quote Originally Posted by ozzyaaron link=1218101506/0#0 date=1218101505
    If someone could suggest an off-the-shelf tamper than fits the Krups non pressurised baskets that people (myself included) are using in the lower end Sunbeam machines that would be most appreciated.!
    Ive sent you a PM re this Aaron.
    Cheers, Anthony
  1. Krups Baskets...
    By sagoode1983 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 24th July 2010, 05:16 PM
  2. Krups baskets for Breville 820:which Krups machin
    By wappinghigh in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th December 2008, 07:07 PM
