Results 1 to 6 of 6
Thread: EM6900 and Wet Steam
    May 2006
    73
    My 6900 was returned to Sunbeam with 2 complaints:
    Wet Steam and a bad seal. The seal was fixed OK, no problem anymore.
    The steam is still very wet I think, I have now measured the amount of water that comes with the steam
    it is 25-30 Ml per minute. Does that seems OK? I called Sunbeam and they said it was measured to be 19 grams
    and it was within the specs for this machine.
    Can I have the valued opinion of some of our members please?
    Thanks in advance
    Apr 2006
    1,562
    Re: EM6900 and Wet Steam
    Yep, sounds like its too wet... My Em6900 is alot dryer than that... send it back... you need to have it sent back 4 times before the EM6900 comes good... thats my experience anyway :-)
    May 2006
    50
    I should check my 6900, I have noticed its a bit wet, but coffee still tastes good.
    May 2006
    73
    Many thanks, both of you. My machine has gone back to Sunbeam.
    Ill keep you posted.
    Apr 2006
    1,562
    dickwyn, youll find that youll get the steam arm and pump installed on it that comes in the EM6910... like I did... and youll be happy with the steam - its quite good... still a little wet but works really well... I get silky velvet microfoam with mine.... :-)
    Marc
    May 2006
    73
    Thanks a lot Marc, Im looking forward to that!
  1. EM6900 no steam! how do i test the pump?
    By Nimrodinder in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st June 2019, 06:14 PM
  2. Sunbeam EM6900 Steam Wand - Back flush
    By bl33ch in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 9th January 2013, 03:55 PM
  3. EM6900 - Steam question
    By Dipsomanic in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 13th August 2012, 08:41 AM
  4. Em6900 steam wand squirting water only,,, and other problems
    By ktk0202 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 19th May 2012, 12:44 PM
