Results 1 to 7 of 7
Thread: VBM Fix for leaky Drip Tray Handle
    Apr 2008
    Brisbane
    5,117
    I have been looking for a cheep and easy fix for VBM owners that have a leaky
    Drip Tray Handle
    This washer is perfect in all ways
    DIY & cheap
    Water proof
    Heat resistant
    And the correct size
    I recommend that you get a hold of a couple of small roofing screws that are also commonly used for sheet steel
    Remove the washer/s from the screw/s (it is easy)
    And use them on your leaky VBM Domobar Drip tray handle
    See photo of what I mean
    Another problem solved ;)
    Koffee Kosmo
    Jul 2008
    86
    Re: VBM Fix for leaky Drip Tray Handle
    Is that a rubber washer or a steel washer? If steel, does it rust?
    Apr 2008
    Brisbane
    5,117
    Quote Originally Posted by garbage link=1224894098/0#1 date=1224933377
    Is that a rubber washer or a steel washer? *If steel, does it rust?
    Itís a good question because the older type washers fitted to roof screws/nails were made of lead
    However these are Definitely Rubber
    In the picture they look cream because the screw heads were painted the colour of the roof sheets
    Aug 2007
    568
    Thanks KK
    I wanted to see if tightening them would work
    If not, add some plumbing tape and / or a washer.
    Needed to know spanner size as will have to go buy one.
    B
    Apr 2008
    Brisbane
    5,117
    Measure across the flat ends of the hex if possible and you will have your spanner size
    Aug 2007
    568
    then I have to go buy a rule :)
    Will do it - was being lazy
    thanks
    B
    May 2008
    600
    You can get o-rings and various rubber or fibre washers from bunnings for around $2.
  1. Silvia drip tray
    By paulcam in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th November 2009, 10:35 AM
  2. Levetta drip tray
    By MarkC77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd April 2008, 01:49 PM
  3. Silvia drip tray
    By pszilard in forum Brewing Equipment (non-machine specific)
    Last Post: 12th January 2007, 10:38 AM
