Results 1 to 6 of 6
Thread: Sunbeam EM6910, is mine haunted?
    Sep 2007
    9
    Around midnight last night I began hearing a sound which I at first thought was distant doof-doof music (esp being Saturday night :) *) but on closer investigation discovered it originated from my Sunbeam coffee machine in the kitchen ...... which was turned off *:o
    It was a slow rythmic beat, not loud at all, but in a quiet house definately could hear it from the next room. Best way to describe it is *the quiet pumping of a fish tank pump but much slower beats.
    I turned off the powerpoint at the wall and the sound stopped.
    Anybody else had their Sunbeam do the same thing? Normal or is mine haunted? *;)
    Aug 2004
    306
    Re: Sunbeam EM6910, is mine haunted?
    Not normal. Youve got an internal leak which is shorting on the main board and switching on the pump. (You may also smell a burning electrical smell).
    I dont want to alarm you, but you need to unplug it, stop using it and get it back to the service centre as soon as possible .
    This happened to mine - and in fact is back in for repairs after a second recurrance.
    Senior Member Stan's Avatar
    Dec 2007
    Just North of Brisbane
    943
    It would appear with Sunbeams when they are turned off unless you turn them off at the wall they are still alive. I have not experienced the noises you have mentioned but would err on the side of caution and get it checked out. :-/
    A_M
    A_M is offline
    Mar 2006
    6,381
    This have been covered in a number of other posts..
    1: Does happen
    2: Sometimes a leak problem
    3: Other times unknown.
    Solution do not leave in STANDBY Mode... The EM6910 heats up quick enough that you should turn it OFF.
    This is also a power saving approach as nothing in standby mode is clean... They all dray some power. Thus Turn it off, your not putting the system at risk and your saving a few cents..
    We turn most things off at night at the wall and when going away (even for a few days) all power points = OFF and the Gas as well.
    In a near 100 year old wooden home - Any fire will do us in... Not worth the chance. Clocks are Battery operated and thus the clocks on the TV / VCR and Microwave etc are not required.
    Sep 2007
    9
    Is my coffee machine haunted?
    Thanks for the replies. So looks likes its nothing as exciting as a haunting ;-)
    It hasnt made the sound since and there was no associated electrical smell, so not sure if I should bother taking it in (and drinking instant till I get it back ;)
    Interested to hear that even with the machine turned off (no lights on) that the unit is still in a standby mode. I didnt see anything in the manual about that, might have another look.
    Aug 2004
    306
    If it is a leak and you ignore it, itll start corroding inside. Id take it in for a check if I were you...
  1. Almost mine...
    By smokeydeck in forum Roasters
    Last Post: 2nd June 2010, 08:56 AM
  2. Halloween Haunted House 2008
    By thegoodies in forum Off Topic
    Last Post: 21st September 2008, 10:48 AM
  3. How do you store your greens?? Heres mine
    By cloudsipper in forum Roasters
    Last Post: 25th January 2007, 02:42 PM
