Results 1 to 8 of 8
Thread: pimping my machine
    Dec 2008
    9
    pimping my machine
    hi all
    looking to buy my first machine, but this post is not about that
    what i want to find out more information about is modding the machine
    im currently browsing coffeeparts, one of the sponsors and they have some great stuff on there
    im looking a getting a new:
    tamper (please do not mention anything about pullmans, i dont have the money)
    steam tip
    and a filter basket
    i want to find out more about the steam tips
    http://coffeeparts.com/accessories/steamtips.html
    would the ones on there fit the machine i will probably get, a breville cafe roma?
    and would they help in better frothing technique? i also understand that a lot of the frothing lies with my skill, and im prepared to learn
    but the biggest one of the 3 is the baskets
    the cafe roma has the "crema baskets" everyone talks about, after reading the posts about it, i wouldnt want one
    but i dont know what the terms pressurized/unpressurized/single/double etc. mean
    im guessing a single and double unpressurized baskets?
    DIY?
    sorry about the length
    all help is appreciated
    cheers
    DONT USE
    Jan 2008
    432
    Re: pimping my machine
    coffee parts do not carry any parts that will fit your machine
    17,209
    Gday "cn"....
    Quite apart from the fact that youd be lucky to find any aftermarket Steam Tip that would fit the Cafe Roma, I dont think it would be a good idea.
    The Cafe Roma is basically a small Thermoblock machine with very limited steam capacity and should you happen to find another tip that does fit, if the hole(s) was even just the slightest bit larger in cross sectional area than the original, you probably wouldnt be able to generate enough steam pressure to move a piece of tissue paper.
    Stick with what youve got for now and learn how to get the best out of it, is the best advice I can give you. Regarding your other questions, if you do a "Search" of the forum youll find heaps of info on those topics. As far as a Tamper goes, get one that feels "right" for you and that does a reasonable job in the PF Basket using a single tamp action only..... Dont get one that is too small and results in your having to chase the compass around the Basket in order to achieve any kind of reasonable tamp - bloody near impossible actually for a newbie. :-?
    All the best,
    Dec 2008
    9
    thx for thr replies
    does the pf basket in the roma measure 58mm across?, as a guess?
    google doesnt seem to be turning up anything
    17,209
    Not as far as I remember....
    More like 50-52mm.
    DONT USE
    Jan 2008
    432
    the Basket in the Sunbeam / breville / Krups machines are a 51 mm
    for replacement filters (non pressuriesed) you should buy the same make, as the wall thicknesses are different
    example = if you use the Krups replacement basket in the breville or the sunbeam, the basket will fall out when you empty the coffee, as the krups has a thinner wall thickness
    if you want to play around with the tip on these machines, then you need to get a whole arm off another model
    some of the tips screw on, some push on others are soldered on
    first you need to buy the machine and use it
    get used to using the standard machine, then when you do change things, you can see if it makes it any better for you
    just because others alter things, doesnt mean that it will suit you or the way you make coffee
    the proof is in the cup
    graham
    Dec 2008
    9
    should i call my local breville service center for the baskets or will they redirect me somewhere else?
    but i do agree i need to try out the machine first, hopefully getting it this weekend
    will try it out from christmas to new year, and after the new year will look at removing the crema system first then some new baskets
    thanks for the insight
    3,498
    Just a warning on the breville baskets....
    If intending to get a fitted tamper at some stage..... these baskets are very poor candidates for such a tamper!
    They slope inwards as you go deeper in the basket.... and have level marks stamped towards the inside of the basket.... both of which foul the tamper....
    You will need a tamper with a largish gap between it and the basket wall.... and it therefore wont be a good fit!
    Krups baskets are FAR better in this regard.
  1. Pimping an aging work-horse...
    By coffeebreath in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th May 2009, 06:13 PM
  2. priming and pimping my gaggia
    By roknee in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 28th November 2007, 10:34 AM
