Results 1 to 3 of 3
Thread: Wet grounds/residue
    Dec 2008
    2
    Wet grounds/residue
    Hi, I have a possible problem with my new coffee machine. Its a Delonghi EC270. After making coffee, the coffee grounds in the filter holder are always wet, verging on a sludge. Apart from being annoying to clean out, I assume thats not such a good thing? Is there not enough supply pressure or perhaps the steam is not hot enough? Should I be worrying at all!
    Thanks for any help
    Senior Member javabeen's Avatar
    Oct 2006
    498
    Re: Wet grounds/residue
    Hi Andyf and welcome,
    Usually a dosing issue, ie that you are not dosing enough (underdosing, or not putting enough grinds in the basket).
    Try filling the basket up so that when you take the portafilter handle (thing that holds the basket) out, you have an imprint of the shower screen thats in the group where the portafilter gets locked into.
    You will need to adjust your grind also.
    Happy brewing,
    JB.
    Dec 2008
    2
    Ahh much better! Thanks very much for you help.
  1. EM0480 - how clear residue after each grind?
    By GHilder in forum Grinders
    Last Post: 5th February 2013, 12:01 PM
  2. Coffee grounds re used ?
    By bintang86 in forum General Coffee Related...
    Last Post: 10th April 2011, 10:22 AM
  3. Black residue in water tank
    By Derkdigler in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st September 2010, 09:24 PM
