Results 1 to 3 of 3
Thread: Question Re Adjusting Brew Pressure
    Apr 2007
    596
    When using a undamped gauge on a vibe pump machine with the gauge fluttering over a 1 bar range which reading do I use e.g. fluttering between 9 and 10 bar do I split the difference and call it 9.5 bar or go with the max 10 bar. Can anyone help?
    Jul 2007
    539
    Re: Question Re Adjusting Brew Pressure
    A way I found to dampen those gauges is to stick a strip of electrical tape over the hole in the portafilter, then make a small hole in the tape with a pin or something like that. In effect youve then made an improvised snubber. That worked quite well on my Silvia.
    Mar 2006
    703
    Yep I suggest to take the average as Bill said.
    BTW Bill thanks for the other tip about the improvised snubber.
    Bullitt
  1. Adjusting the brew pressure (OPV) on Isomac Mondiale
    By hazbean in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 27th November 2014, 12:52 PM
  2. Adjusting Giotto Premium Brew Pressure
    By dumiya in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 15th November 2010, 10:43 AM
  3. Adjusting brew temperature to tune a shot flavour characteristics
    By onewheel in forum General Coffee Related...
    Last Post: 30th April 2010, 05:02 PM
