Results 1 to 11 of 11
Thread: Size of hole in the benchtop
    Mar 2008
    466
    Hi,
    My parents are building a new house and plan on getting a plumbed in coffee machine so they came to me for advice. What I need to know is how large a hole is needed to be drilled into the bench top to facilitate water in, drain out and power.
    Thanks in Advance.
    MM
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Re: Size of hole in the benchtop
    Hi MM
    Simple. A slightly larger diameter than the power plug. As long as you feed that through first, the rest will follow. ;)
    Jul 2008
    Port Fairy
    2,993
    What you want to put in is one of these
    Standard are 60 and 80mm and under $10 :)
    Apr 2007
    323
    If you want to minimise the size of the hole, remove/cut off the plug, feed the power cord through and then reattach/rewire the plug. Bunnings sell DIY plugs for chump change.
    Apr 2008
    Brisbane
    5,115
    Quote Originally Posted by 56637A702425130 link=1241510347/3#3 date=1241521539
    If you want to minimise the size of the hole, remove/cut off the plug, feed the power cord through and then reattach/rewire the plug. *Bunnings sell DIY plugs for chump change.
    Nothing against your suggestion Epic
    Thats OK for the power cord but MM wants the water in, drain out and power.
    So for that reason I agree with Beanflyings suggestion
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 496D646467675D496D716F6D020 link=1241510347/4#4 date=1241527354
    Unless your licensed... Removal of a plug is OK; but to re attach a power cord or a plug is ageist the law in Qld.
    Stay safe guys..
    17,406
    Yep,
    I "third" bfs suggestion 8-). Not only can you obtain these through-bench bushings/grommets but you can also get blanking covers in a few different colours for later on, if they decide to move house and leave the benchtop in a presentable state,
    Mar 2008
    466
    Thanks for the advice. I think they will go for the Grommet idea, kinda like (or exactly like :) ) the ones in computer desks.
    Jul 2008
    Port Fairy
    2,993
    Kind of exactly indeed :)
    I had a bit of a scrounge around last week as I am building a new shop counter and I found some timber ones in the UK and also some in metal trim.
    Jarrah counter deserves timber outlets 8-)
    May 2008
    600
    How about going through a wall? Might be easier to patch up later if they change their mind.
    Apr 2007
    323
    Quote Originally Posted by 0E2A232320201A0E2A36282A450 link=1241510347/4#4 date=1241527354
    None taken! It was made "in addition" to the blanking cover, not instead of. A way of minimising the size of hole & cover used.
    *makes note to self - dont abridge posts* :)
  1. Hole Size for Plumb-In
    By Seeya_Latte in forum Brewing Equipment (non-machine specific)
    Last Post: 26th February 2010, 11:24 AM
  2. 4 hole tip down to 2 hole for FAEMA Due
    By ozscott in forum Brewing Equipment (non-machine specific)
    Last Post: 28th December 2007, 05:19 PM
  3. My benchtop Corretto
    By greenman in forum Roasters
    Last Post: 29th October 2007, 07:32 AM
