Results 1 to 8 of 8
Thread: Leaking Nemox
    Jan 2005
    2
    Leaking Nemox
    I just bought a Nemox dell Opera (similar to the Napoletana - see http://www.lygonimport.com.au/product_details.php?pid=49 for details) and have a quick question. A couple of times in my first week with it, I have filled the coffee filter too much, or have tamped the coffee too firmly, as its taken too long for the espresso to brew. Thats fine - teaches me to use less coffee or not tamp so firm.
    But what is more worrying is that when this happens, the machine leaks - there are drips from the right of the front of the machine, just below the switches. My question is, is this leaking just a sign that Ive overfilled the coffee basket, or is it more serious than that and I should get it looked at?
    All advice is appreciated.
    Timothy
    Aug 2004
    125
    Re: Leaking Nemox
    Timothy
    Id try to fill the basket correctly and tamp and get my 25 second run-of-the mill shot first. Youll probably find its just coffee escaping the group seal.
    Some of these machines seem to leak a little coffee around the portafilter until the the gasket breaks in a little.
    See how you go then -
    Warren -
    Aug 2004
    2,312
    Re: Leaking Nemox
    If it is leaking water (not coffee) from the position you describe, it can only be coming from the boiler asssembly therefore, take it back and have it checked.
    Regardez,
    FC.
    Apr 2004
    327
    Re: Leaking Nemox
    Looks like its a nice machine Tim, Hope you get if fixed. ;-)
    Good Luck
    FB
    17,476
    Re: Leaking Nemox
    Hi Timothy,
    I had a similar problem with my machine (Imat Mokita Super Inox... aka Nemox w/o Grinder) and discovered, with Alan Frews very valuable assistance, that the problem was with the "Swivel" fitting on the Silicone Tubing that goes from the Pressure Relief Valve to the Water Reservoir.
    The PRV is fitted to the discharge end of the ULKA Pump where the High Pressure line goes off to the Boiler. All that had to be done was to remove the Rubber Swivel Fitting from the PRV, it just pulls of with relatively little force, check it to make sure that there is no foreign matter in there, clean if necessary and then push it firmly back on to the nipple of the PRV so that it wont pop off.
    Mine had what appeared to be a small O-ring segment inside the fitting. I just removed this and pushed the Swivel Fitting back on to the PRV Nipple and that was the problem solved. The reason you only see water leaking from your machine when you "stall" the pump is that most of the water from the pump is being diverted back to the reservoir under these conditions and if the Swivel Fitting is not properly attached to the PRV or something is preventing a proper seal, then that diverted water will leak and exit from the machine via what ever is the easiest path.
    Hope this helps you out. All the best,
    Jan 2005
    2
    Re: Leaking Nemox
    Thanks heaps for the replies everyone. Mal, it sounds like Im having the same problem as you did - I will look into that.
    Cheers, Timothy
    Aug 2004
    2,312
    Re: Leaking Nemox
    Suggest you call the vendor, importer or service agent, ask advice, see if they mind you getting into the machine or whether this would void your warranty.
    Regardez,
    FC.
    17,476
    Re: Leaking Nemox
    Quote Originally Posted by Fresh_Coffee link=1105657459/0#6 date=1106022813
    Hi F_C and Timothy,
    Good advice F_C. In my case Alan Frew was the vendor from whom I purchased my equipment and it was only after talking to him about the problem that he suggested I should open up the machine and do as I indicated above.
    Yessir, always consult with the vendor before opening up any machine still covered by manufacturers warranty. All the best,
  1. Leaking EM6910
    By C15CO in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 23rd September 2011, 02:00 PM
  2. Leaking Machine.
    By pco203 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 16th June 2010, 10:55 AM
  3. [m]: cimbali jr leaking
    By Dimal in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 18th October 2008, 01:52 AM
  4. Nemox Dell Opera - Leaking Hose
    By pluggulp in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 21st July 2008, 12:58 PM
