Results 1 to 4 of 4
Like Tree1Likes
  • 1 Post By Fresh_Coffee
Thread: vittoria classica help
    Oct 2008
    66
    hey all
    a mate of mine bought a cafe recently but and was unfortunate enough to inherent a vittoria classica that had been terribly maintained! now before he upgrades he still wants to make this work better for him. Ive walked him through the cleaning and maintenance, but Ive had a look at the poor times and theyre.. well... wrong!
    doe any one know where i can get a manual for this machine for him, or even just how to adjust the poor lengths
    cheers
    joe
    Aug 2004
    2,312
    Re: vittoria classica help
    Hi there.
    Owner manuals for espresso machines generally tell you nothing and the translations to English are usually sub standard. My advice for that is dont waste your time.
    This is the way touch pad programming will most likely work:
    Place the correct dose of correctly and freshly ground fresh coffee beans in the group handle and tamp accordingly.
    Acivate & purge the group of any super hot water for whatever length of time is required to get the desired result.
    Apply the group handle to the group.
    Press the star button and dont let go until all the leds light up.
    Within 5 seconds press any one of the buttons you wish to programme.
    (.....If you do not make a selection within the 5 second window it will likely drop out of programming mode and you will have to press the star button again as previous....)
    The group will start to brew in the normal way, except that it is in programming mode and will not auto stop until you again press the button (which you will do when the level in cup reaches the point that you want it to stop at.
    That button is now programmed.
    Start again from the top but press one of the other buttons that hasnt been programmed yet and complete the cycle as above.
    Repeat until all four buttons are programmed in the way you want.
    If you want to change one that you have already done, simply do that one again.
    You must use a fresh puck of coffee every time for each button.
    Hope this helps.
    Regardz,
    Attilio
    very first CS site sponsor
    PS 1
    its easy to do and you dont want unauthorised staff to fiddle this so best to do when only authorised staff, supervisor or owner are around.
    If attempts at programming fail (as in, you programme something but it subsequently pours something different every time), but you have followed the above instructions consistently, then something is wrong.....very possibly the paddle wheel or sender unit of the volumetric flow meter needs replacing.
    PS 2:
    If we all think my explanation of the programming process was clear and concise and in view of the usually terrible instructions provided in so called "owner manuals", Ill see if I can sell my clearly articulated instructions to all and sundry manufacturers to insert into their manuals! :D
    matth3wh likes this.
    May 2007
    100
    Quote Originally Posted by 251106100B3C200C05050606630 link=1247104079/1#1 date=1247123274
    Hi there.
    Sounds like a bottle full of experience. I could understand it. Hope it helps Joes mate.
    Oct 2008
    66
    mate spot on!
    thanks heaps will pass it through to your credit! and will hopefully get a decent restretto up there now!
    cheers
  1. B.F.C. ALA di VITTORIA 1GV EL 1 group - a.k.a. GRIMAC VITTORIA One Group - a.k.a. DIADEMA 1GV EL
    By fabcat in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 12th June 2019, 05:10 PM
  2. New Machine: BFC Classica Help
    By jjjones in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 9th June 2012, 12:52 AM
