Results 1 to 13 of 13
Thread: Drip Tray grunge
    Jul 2007
    2,288
    Drip Tray grunge
    I know, I know. I should really scrub out the drip tray every coffee or so! >:(
    But I dont--and the brown scum showing through the screen really detracts from the aesthetic experience of brewing. :(
    Has anyone painted the inside of their drip tray black (or have one with a black lining)? How does this work? What do I use to paint stainless so it stays put?
    17,406
    Re: Drip Tray grunge
    Quote Originally Posted by 45706765556D706F636E66020 link=1251018748/0#0 date=1251018748
    That truly is sacrilege Greg.... :o
    I clean mine out every couple of days, only takes 30-40 seconds, a good wipe down with a m/f cloth and looks like new. Cant imagine ever leaving any crud to build up... :-?
    Apr 2008
    Brisbane
    5,115
    You will find that although you can successfully paint stainless steel its the liquid immersion that is the problem
    Find a black plastic tray that fits neatly inside yours. Thats the way its usually done
    Apr 2006
    4,126
    Oh for crying out loud...
    Just clean it! *;D :P
    Itll take about 20 seconds of your time under hot water! *::)
    Either that or build yourself a bridge! (and get over it!) ;D
    Or...
    Take a cement pill... ;D :P
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 796965657E6B556D6B660A0 link=1251018748/3#3 date=1251031479
    Or...
    A bit of that Sponsors cleaning powder and it cleans its self.. *Empty when the splashes and dribbles make a mess on teh bench top..
    Jul 2007
    2,288
    Quote Originally Posted by 143039393A3A0014302C32305F0 link=1251018748/2#2 date=1251029609
    You will find that although you can successfully paint stainless steel its the liquid immersion that is the problem *
    Thanks KK, I hadnt thought of that--Ill see what I can come up with.
    Unfortunately, (and seemingly unlike Mal), I can see through the screen on my drip tray and after only two or three coffees the water is brown with coffee oil staining the surface. Imagine cleaning it only every few days!
    Heaven knows how caked up his screen is -- it appears he cant even see through it! ;D (Either that or my bifocals just put the bottom of the tray in focus.)
    10,496
    Mine only gets scummy if I only tip the water out without wiping a few times in a row.
    The Expobar has a 2 litre drip tray so has the potential to be gross but I hardly ever let it get into that state.
    Clean it!
    17,406
    The only water/detritus that ends up in the drip tray of my DJE comes from the 3-Way exhaust. Everything else is directed into a black plastic cup that Ive used for that purpose for several years.
    Oh, and my eyesight is fine thanks ;)....
    Apr 2009
    115
    just clean it.
    Aug 2007
    569
    I normally just empty it every couple days, and then give it a good clean post backlushing, as the cleaning chemicals get rid of all the oils.
    Mar 2006
    703
    I Just rinse mine out after each brewing session as part of the general clean up, doesnt take long as many have noted, and then next time I use the machine the drip tray starts empty and looks clean.
    Whenever you do a chemical clean the drip tray should come up like new with a quick wipe out.
    I guess one advantage of the relatively small drip tray on Silvia, is that you cant easily leave it for ages to get all scummy.... ;)
    Aug 2009
    78
    A little black tray inside your tray sounds like a great solution ...my drip tray is a black tray so I cant see the contents. I routinely empty and wash it at the end of each day when I put my machine to bed for the night or while I am doing the dishes.
    Sep 2008
    249
    Mine goes in the dishy once a week - comes up beautifully!
  1. Silvia drip tray
    By paulcam in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th November 2009, 09:35 AM
  2. EM6910 Drip tray issue.
    By adix in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 2nd November 2008, 08:14 PM
  3. Levetta drip tray
    By MarkC77 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 3rd April 2008, 12:49 PM
  4. Silvia drip tray
    By pszilard in forum Brewing Equipment (non-machine specific)
    Last Post: 12th January 2007, 09:38 AM
