Results 1 to 3 of 3
Thread: Sirai pressurestat - rebuild or replace
    Sep 2005
    146
    The deadband of my sirai pressurestat is too wide at 0.4bar. It is the older style with the gray/blue metal box.
    Coffeeparts sells new membrane kits - will it fit these older sirai pressurestats or do I need to simply replace?
    If it will fit, is it wise to spend the extra $50 to just replace? Why?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Re: Sirai pressurestat - rebuild or replace
    Quote Originally Posted by 4E554D5F0A0C0A033A0 link=1275739803/0#0 date=1275739803
    New = ?
    Refurb kit = ?
    Time and effort... *In addition if *the unit its self was flaky one would always just replace. *The fact that there is a refurb kit; indicates a couple of things.
    1: *The main system must be robust and or expensive
    2: A refurb kit is also a method of upgrading the internals as advancements or different needs are required..
    Your call.. Both will take some effort and cost.
    Any activity that involves electrical parts must be performed by a qualified and licensed maintenance technician
    Mar 2008
    6
    hi Timo
    there are two different sizes in the pressurestat, so if you intend to service it you need to measure the diaphram.
    In most cases you are better to replace the whole unit
    apart from the diaphram drying out and loosing its flexability, the electrical contacts burn out, and dont make proper contact.
    these are not able to be cleaned succesfully
    graham
  1. EM6910 rebuild or replace?
    By camerond in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 20th April 2013, 09:50 PM
  2. Do Sirai Pstats suffer from temp creep ?
    By maheel in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd May 2010, 10:27 PM
  3. FS- NEW Sirai Pressurestat
    By Wushoes in forum SOLD
    Last Post: 16th January 2009, 05:29 PM
