Results 1 to 5 of 5
Thread: Leaky Silvia
    32
    Leaky Silvia
    Hi All
    Occasionally while my Silvia is on it leaks from the steam pipe, not a great deal but enough to make a small pool of water on the bench unless I see this happening and tighten the steam knob.
    Has anyone else experienced this??
    Tim
    Aug 2004
    125
    Re: Leaky Silvia
    Tim,
    Probably your usual case of metal expanding when hot and contracting when cold (steam valve). No drips when warmed up because the valve and associated gaskets seal themselves.
    Mine does exactly the same thing. Important thing to remember when turning your Silvia on is to just tighten the steam knob a bit. Just so it firms.
    Mine will let out a drip or two five minutes or so after switching on. Youll also notice that the knob will turn freely clockwise just a touch when cold.
    Nothing to really worry about. Just remember not to over tighten the knob or youll wear the seals. :)
    Warren -
    Dec 2004
    Earth!
    16,153
    Re: Leaky Silvia
    I dont have a Silvia, but I have noticed this happening on other units Ive used. I tend to tighten the knob the minimum amount needed to stop the flow of steam/water. As the valve cools down the washer/gasket that seals it also cools and contracts causing the valve to leak a bit until its retightened. On my espresso machine once Im done cleaning the head and backflushing after pulling a shot the valve has usually cooled enough that a slight tightening of it at that point is enough to keep it from leaking later.
    Java "Back to the plaster dust I go" phile
    Dec 2004
    Earth!
    16,153
    Re: Leaky Silvia
    I had a laugh Nice timing Warren! Beat me by seconds!
    Java "Isnt remodeling FUN" phile
    Aug 2004
    125
    Re: Leaky Silvia
    Must have been neck and neck Javaphile were both listed as 9.35pm. Your message must have come through a longer cable. ;D
    Warren -
  1. Leaky Silvia - Melbourne Repair?
    By digitalbugsy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 10th April 2013, 05:59 AM
  2. Silvia leaky steam arm, which part do I need?
    By muppet_man67 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th July 2011, 08:50 PM
  3. Leaky Silvia - Assuming Rubber Seal - Can you help?
    By nelo784 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th March 2010, 07:17 AM
  4. New silvia (2nd hand) old/leaky group seal
    By andrew in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th May 2008, 06:24 PM
  5. leaky portafiller, Miss Silvia
    By extracto in forum Brewing Equipment (non-machine specific)
    Last Post: 14th August 2006, 07:14 AM
