Results 1 to 19 of 19
Thread: Mobile Coffee Trailer Specs - Any Good?
    Oct 2010
    4
    Hi guys
    First post on this forum - hope Ive put it in the right spot!
    I am looking to invest in a mobile coffee trailer. *Thought about the van idea, but since I already have a vehicle capable of towing a trailer, I thought I would go with the cheaper option. *My thinking is that if it doesnt go well, I can flog the trailer a bit easier than a fully kitted-out van.
    My main targets (customers :)) will be construction sites, industrial areas, and events. *I want something small enough to be agile, but large enough to handle medium-sized events (I live in an outlying suburb and will be catering to things like horse riding shows, fetes, and of course the footy and cricket matches).
    Ive exhausted my Google searching to find manufacturers for trailers, and looks like Coffee Bella comes up trumps - in fact, it seems to be the ONLY manufacturer (please tell me if Im wrong - particularly if anyone knows of a manufacturer in WA!). *Im not particularly handy, so outfitting my own trailer isnt an option.
    Ive attached the specs below for the "small walk-in trailer" and would love your comments on the gear and price - is it reasonable, and would it be enough for my needs? *Especially interested in comments about the espresso machine - any good?
    Price is $33K GST inclusive.
    Another point is that I need it to have room to make juices or smoothies or iced coffees - it gets pretty hot here and summer wont be just for coffee - does this look like it has enough room for a machine?
    Thanks everyone - dont be afraid to be honest!
    *note* - Ive tried attaching the PDF original document with pics etc, but it is apparently too large (1.5 MB). *I can send this through to anyone who wants to see it - I can only attach the trailer layout.
    Geoff
    Walk In Trailer
    Walk In Coffee Trailer ( 2100 x 1500 )
    This walk in trailer is designed to allow you to cater for events, road side, parks
    and markets selling fresh coffee, drinks and snacks from the comfort of your own
    work area, standing on the inside serving customers on the outside.
    • Solid 2100 x 1500 single axle trailer
    • Solid metal undercarriage with heavy duty gear
    • 3 x Mag Wheels
    • Finish in either white fiberglass or painted metal
    • Checkerplate aluminium in “stone chip” zones
    • Serving counters and lockable hatches on the footpath side and the rear
    • Personal door on drivers side – fully lockable with insect screen
    • Benches on three sides
    • Stainless Steel Finish to all work benches, 304 food grade stainless, No. 4 finish.
    • All benches with splashback up against walls
    • 1 x Coffee Machine – Diamond Prima – Italian two group commercial machine
    • 1 x Compak k-3 elite grinder
    • 1 x Engel 57 litre milk fridges ( 12 volt ) Hold 11 x 2 litre milk each – mounted under bench
    • 1 x 60 EvaKool Fridge Freezer
    • 2 x cup dispensers mounted under the bench
    • 1 x side stainless steel sink 240mm x 140mm mounted in stainless steel bench
    • 1 x stainless tap to sink delivering pressurized water
    • 1 x pre-filter before water pump
    • 1 x fine filter before coffee machine
    • 1 x external water fill point with key
    • 1 x digital water level meter on main water tank
    • 1 x 80 litre Fresh Water Tank mounted under trailer
    • 1 x waste tank 40 litre receiving waste from coffee machine and sinks – with air breather
    • 1 x under trailer tap to empty waste water
    • 1 x 3kva Honda EU30i generator
    • 1 x roof mounted whirly birds
    • Complete 240 volt Electrical circuits all to Australian standards
    • Power board with earth leakage circuit protection
    • 1 x external weather proof power plug
    • 1 x 20m 15 amp extension lead
    • Complete 12 volt electrical system ( operates milk fridge, lights, water pump ) with ….
    1 x 100 amp hour deep cycle battery,
    1 x CTEK battery charger
    1 x water pump
    4 x ultra bright flouro lights
    • 2 x steam jugs
    • 1 x tamp
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Re: Mobile Coffee Trailer Specs - Any Good?
    Hi geoffro and welcome to CS.
    I wont pretend to know anything about setups like this, but I do know that fridge capacity seems mighty small!
    Jul 2008
    Port Fairy
    2,993
    Just my thoughts on serving from a trailer it while having everything contained in a tow and go package is great it has some problems.
    Cant get inside some venues so you will miss some jobs. Detachment from the customers as you are staring down from them from above. Very cosy if 2 of you are trying to move around.
    Seriously look at a cart with good trailer unless you are wanting to move it several times a day and then the vans are used for a good reason.
    Oct 2010
    4
    Hi guys -
    Thanks for the replies. I agree with you about the fridge - it does seem awfully small. Would definitely go for a larger capacity.
    Beanflyin, can you explain a bit more of what you mean about a cart with a good trailer? Are you talking about a coffee cart that is carried about on a standard trailer?
    Geoff
    10,496
    From what Ive read you can get standard trailers modified to securely load a coffee cart.
    Search google for "coffee cart trailer" for a better explanation.
    Oct 2010
    4
    Hi Thundergod (and everyone else)
    Cool, will do. Can you all please explain how this would be an improvement on the walk-in trailer idea? Is it a bit more agile and more customer-friendly?
    What sort of jobs would one miss out on if they were using the bigger trailer (besides office work, which Im not aiming for)?
    Thanks for all your input - it really helps!
    Geoff
    Oct 2009
    29
    if you are keen on a trailer more than a cart setup in a trailer...
    For me, the best trailer set ups are the ones where the barista is on the ground using the door as a canopy. a good one i saw a while back had 3 doors open one with coffee gear etc one side for cold drink display and one side for food and storage,
    standing inside a tin trailer with lots of heat generating equipment not so much fun in summer.
    This sort of tailer will normally be much smaller than one you can stand in aswell.
    Jul 2008
    Port Fairy
    2,993
    This sort of thing. Also while you may not want office gigs there is money in indoor sporting gigs, art openings and a whole lot of other situations where a trailer simply wont go. Even the local markets the cart will fit in better and presents better to the customer than a trailer.
    Some info here on milk/coffee ratios that might help with the fridge answer http://coffeesnobs.com.au/YaBB.pl?num=1265938570/0
    Another more general ramblings on mobile coffee http://coffeesnobs.com.au/YaBB.pl?num=1270821027/0
    Lastly your 3kVa gen set is to small you really will need a 5 or even 6 kVa. Grinders need 3 times running load to start well plus 3kW of boiler and your at least 1kVa short.
    Dec 2007
    921
    The list had batteries so maybe the generator is just for topping up the batteries? I would steer away from batteries though as they are expensive and need replacing every two years or so, where as a decent generator if not used a lot (which I imagine you probably wont) will last years. Do a search for coffee carts australia and that will give you a lot of pictures to look at for ideas.
    Brett
    Sep 2008
    759
    As the owner of such a coffee cart and trailer Id like to offer some perspective in comparison to a trailer setup.
    The positives are that you are at the same level as your customer. Interaction is much easier.
    The negatives:
    Setup time and effort is huge. It often takes me 45 minutes from arrival to ready to trade, with two people.
    The cart only allows for a small fresh and dirty water tank, so carting water is frequent and labourious.
    You are very exposed to the elements unless you have a marquee, which increases setup time and effort.
    Things such as grinders, consumables and other accessories need to be stored outside the cart as access is not easy without unloading the entire thing off the trailer. So that makes more loading and unloading to and from your car or van before during and after your event.
    Most carts require a hard surface to maneuver on. So a grassy or unsealed dirt area is gonna make it difficult.*
    Carts are great and have their place but if you intend on being at a different site each time, I wouldnt go for a cart.*
    -ACog
    Dec 2007
    921
    I also own a cart and can 100% agree with ACog, there are cart options which will allow you to operate from the ground. You may just have to think outside the square a little.
    Also any trailer manufacturer can make this for you, it is just up to you to come up with the design. Might take a bit of extra work but it will save you a packet.
    Brett
    Oct 2010
    4
    Hi all
    Thanks so much for your input. Im putting quite a bit of thought into the pros and cons of this venture. Not so sure a coffee cart will do the job for me at this juncture, but will have a hunt around and see what I can find out about the cost and functionality of the cart vs trailer.
    If I have any more queries, I will definitely post another question - your support has been fantastic! 8-)
    Jun 2006
    60
    My wife and I operate a mobile espresso van here in the states and I will gladly address a few issues I see.
    -Even though I like the Compak grinders I question whether the K-3 can keep up with a 2 group machine when really cranking out lots of drinks.
    -It appears your fresh water tank is TWICE the size of the waste tank. Unless part of that fresh water is being used to make ice and draining under the trailer, you always want a larger waste tank than fresh water capacity.
    -Also agree you need more power to run. We have a 2 group NS Aurelia (4500 watts), 3 grinders, an icemaker, 2 commercial blenders, an overhead Carrier AC unit, full size refrigerator, 2.5 gal hot water heater, fluorescent lighting, 3 water pumps and a few other things and it takes everything this generator cranks out when all of this fires up simultaneously. Add up total combined power usage and get something rated maybe 15-20% higher than that. Also go with a propane fired generator if possible as they run a bit quieter, more efficiently and cleaner burning for less smell.
    -Your external power lead needs to be much higher than 15 am capacity. We have a 220v/50 amp connection when plugged in.
    Jan 2009
    83
    K-10 Conical
    Faster than you.
    Dec 2007
    921
    Quote Originally Posted by 627970757E66262524110 link=1286277678/12#12 date=1286978119
    Curious as to why?
    A_M
    A_M is offline
    Mar 2006
    6,381
    Best guess..
    While some water wil be used. Add in milk, melting ice, washing suds etc etc. *
    If ya light on with water you can go and get some. *Once ya waste backs up and starts frothing and overflowing... Potential clients remain just that. The people running the place may also have concerns with WHS and cleanness .
    Dec 2007
    921
    I have seen some carts/vans with specs where the waste water is larger than the fresh and in my experience I have never had an issue so I was just looking for the reason behind it. Come back shadow and fill me in!
    Oct 2012
    1
    Hi there - i'm sorry to drag up an old thread but just wondering if anyone here has ever dealt with Coffee Bella? I'm just about to give them the go ahead to build me a coffee van and just wanted to see if anyone here has a van or trailer from them.
    Senior Member sidewayss's Avatar
    Jun 2010
    Perth, Western Australia.
    1,434
    I've been in contact with a couple of people who use Coffee Bella built products. Both the trailer and ute was built to a good standard. The operators are happy with the workmanship.
    The K3 is not up to speed with multiple coffees. Demand the K6 or the Mazzer Jolly as the minimum standard.
    They can help with finance too. Friendly and helpful to deal with.
  1. Coffee Trailer - any suggestions.
    By Maverick in forum Off Topic
    Last Post: 24th February 2016, 07:46 PM
  2. Mobile coffee trailer fitouts in Melbourne ?
    By es4u in forum General Coffee Related...
    Last Post: 10th August 2009, 03:25 PM
