Results 1 to 6 of 6
Thread: Fitting a Solid State Relay (SSR)...
    Jan 2007
    104
    Quote Originally Posted by 426F6B676A060 link=1234688068/62#62 date=1288193232
    SSR rated at between 25-40A would cost in the neighbourhood of $30 +/- $5.00
    Found one that meets the spec (40A and 240VAC), but they supplier recomends to use the optional aluminium heat sink with it. Any tips on that front? They also said its fine as long as its mounted to a metal frame, but I dont think I have much frame space left.
    16,771
    Re: Fitting a Solid State Relay (SSR)...
    Quote Originally Posted by 04010E0555545351600 link=1234688068/63#63 date=1288218151
    If you cant locate it on some bare frame metal (with silicone thermal interface material) then a Heatsink is your only option Im afraid. Theyre not very big units you know, so am a bit surprised that you cant find a spot to attach it.
    Either way, the ideal location would be as far away from the Boiler as is practical, as low down as possible and away from any potential exposure to spilled water otherwise protection needs to be provided.
    All the best mate... :)
    16,771
    [movedhere] Brewing Equipment (non-machine specific) [move by] Mal.
    Jun 2010
    217
    I am going to use Jaycar CAT. NO. HH8572 $9.95
    High Efficiency Fan Type Heatsink - 75mm Long
    Available in various lengths.
    - 105mm wide.
    - Thermal resistance 75mm unit 2.5 C/W;
    http://www.jaycar.com.au
    just remember the SSR is going to be using *5A to 6A (1200W to 1440W) and the duty cycle is only 1/5 or less, it only going to be working hard when warming up from cold first few minutes after that it just a brief pulse to stay at brew temperature. Steam uses original steam thermostat and not the SSR.
    my gaggia baby is plastic case , currently using internal PID relay and 20s response time, but will use SSR with Heatsink and 2s response time.
    by the way i got a 25A SSR for for $10 from sure electronics, they also on ebay, they also sell PID $31
    http://www.sure-electronics.net/
    Oct 2008
    505
    The heat that the SSR needs to dissipate is the voltage drop (usually 2V) times the amps the element draws.
    So if an element is 2400Watts it is drawing 10amp. So the energy that SSR will use is 10amp time 2volt = 20Watts.
    Jun 2010
    217
    here is a detailed data sheet for some SSRs
    http://www.opto22.com/documents/0859_Solid_State_Relays_data_sheet.pdf
  1. Carimali Relay
    By jamies in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 11th August 2011, 06:58 PM
  2. ISOMAC MONDIALE Solid Steel Portafilter handles
    By scp1906 in forum Brewing Equipment (non-machine specific)
    Last Post: 1st February 2008, 04:44 PM
  3. Solid and Simple
    By luca in forum Blending Room
    Last Post: 13th April 2007, 03:22 PM
