Results 1 to 28 of 28
Thread: Any tips for dose quantity gadgets?
    Dec 2010
    67
    I know about the Scottie Callaghan dosing tools and for now an old credit card with two different arcs cut on the long sides is meeting my needs. But I have a question about bean dose, not grind dose. I have a doserless Rocky and dont want any beans left in the grinder after I make my shot. Im using a plastic measuring scoop to get the right amount of coffee into Rocky, but a few beans more or a few beans less can make a big difference to the final dose. How are others dealing with the issue of getting the exact same amount of beans into your grinder for each shot? Is there something like the Scottie C kit but for bean quantity rather than final grind level?
    Aug 2010
    204
    Re: Any tips for dose quantity gadgets?
    Digital scale.
    Apr 2008
    Brisbane
    5,113
    DIY one from a business card
    Also level fill the basket you use with beans as a very accurate guide of the amount of beans to grind
    May 2009
    52
    +1 for the scales. I use a cheap (<$15 shipped) set of digital scales from DX that are 300g max with 0.01 gram resolution. More than adequate for my needs.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,866
    Digital scales, cheap, quick and very accurate, add to this a small brush to clean the chute and doser out and its pretty much a case of 18 grams in 18 grams out. ;)
    Aug 2010
    204
    SeanSheep... nice scale! Do you mind sharing the brand?
    Something weird happened with mine today or my cleaning technique changed a bit... I usually get ~0.5g less than what I put in... I ended up with more than I put in! :(
    Dec 2010
    67
    Ditto vyapadas question: I seached the DealExtrem site and cant find a digital scale that looks like SeanSheeps. They look cool.
    May 2009
    52
    I dont want to breach any posting guidelines, so mods if this is too much then i apologise and feel free to delete.
    If you go to the site in question these are the product numbers, which are searchable:
    17486 300g/0.01g Black
    17481 300g/0.01g Silver
    17485 200g/0.01g Black
    17480 200g/0.01g Silver
    Mine is actually the 200g/0.01g Black model (not 300g).
    Aug 2010
    204
    Oh, I had no idea DX was dealextreme, haha. Cheers mate!
    If mine ends up throwing a tanty I might need to get a replacement.
    16,768
    Quote Originally Posted by 514A404B425147424F424142230 link=1297899281/0#0 date=1297899281
    Its not very often that I get to pull only one shot in a session but on those occasions that I do, I just use a standard 1 Tablespoon Measure x 2. Just strike the beans level with the rim and dump into the grinder. About 19g +1.0/-0.0 whole beans go in...
    After first pulsing the grinder a couple of times (to remove any old grinds, about 1.0g) then grinding properly and sweeping out the grind chute, I end up with about 18g +1.0/-0.0 of fresh coffee grounds. After dosing , I end up with either a perfectly level dose in the filter basket or a very slight mound that gets swept off.
    Makes a perfect shot every time (even if I do say so myself).... ;) 8-) and no need for digital scales or any other device.
    10,496
    I use the palm of my hand to feel the level in a spare basket that is now only used for measuring beans to go into the hopper.
    Ive checked the accuracy of my hand using digital scales and its consistent.
    Aug 2010
    204
    Quote Originally Posted by 6E524F545E5F485D555E3A0 link=1297899281/10#10 date=1297926168
    Nice! What kind of resolution do you have? ;)
    Jun 2009
    Moonta SA.
    6,866
    Quote Originally Posted by 003C213A303126333B30540 link=1297899281/10#10 date=1297926168
    How often do you recalibrate your hand? ;)
    10,496
    Quote Originally Posted by 76796170616461000 link=1297899281/11#11 date=1297928677
    Only 1g.
    Quote Originally Posted by 59656C7461000 link=1297899281/12#12 date=1297929850
    Not often enough for you so Ill try get around to it tomorrow.
    Nov 2009
    Altona, Melbourne
    1,577
    How do you account for the uneven grind that gets produced when there is no wait settling the beans onto the burrs?
    I have seen some people use their tamper as a weight, is this what you do?
    10,496
    Any uneven grind is consistent. ;)
    Senior Member shapeshifter's Avatar
    Oct 2010
    Newcastle
    726
    Weve got the same (or very very similar anyway) scales as sean, great little scales, we call them our drug scales as you can get such small quatities *;D
    I do tend to go on the level in the kyocera but in saying that some beans have a different weight depending on how Ive roasted them, so back to the scales :)
    Ill have to try the beans in the basket and see what happens too.
    10,496
    Quote Originally Posted by 7A465B404A4B5C49414A2E0 link=1297899281/13#13 date=1297943866
    Nice! What kind of resolution do you have? *
    Only 1g.
    Opened a new bag of beans this morning.
    There was a bit of variation in the bean size with a noticeable amount of smaller beans scattered throughout.
    Filled my basket and levelled with my palm.
    Weighed.
    Came to just short of 22g; readout was flashing 22/21.
    Emptied the basket back into the bag and shook then measured the same way again twice more.
    Both times I came within one or two beans of the same weight.
    :P
    May 2009
    52
    Two-bean resolution. Youve gotta be happy with that. ;)
    Tried the levelled scoop method today and it was surprisingly accurate at almost exactly 9g per scoop.
    May 2009
    52
    Quote Originally Posted by 4543545F45425A58310 link=1297899281/14#14 date=1297986552
    Cant say Ive ever noticed any inconsistency in the grind. It all looks uniform.
    But then Ive always done it that way, so I havent really got anything to compare it to.
    10,496
    Quote Originally Posted by 794F4B4479424F4F5A2A0 link=1297899281/18#18 date=1298015170
    Of course.
    I did say my hand was accurate.
    Anyway, Ive just recalibrated my hand down to 19g as 22g was close to the updose limit for my showerscreen.
    19g fits nicely with a bit of extra wiggle room for puck expansion and those 1 or two beans than might have Jon worried for me.
    A_M
    A_M is offline
    Mar 2006
    6,381
    Quote Originally Posted by 1529342F252433262E25410 link=1297899281/20#20 date=1298092261
    Of course.
    giggled like a schoolgirl...
    Yep teh HAND can be calibrated for many functions...
  23. #23
    Dec 2010
    67
    Thanks for some interesting comments. Im interested that some people are using their baskets as a measuring device. This is a question worth some scientific testing: IF unground beans filled the same volume as the same beans that have been ground, then using the basket would be an ideal measuring device, especially as I have four baskets that are used depending on who wants what strength shot - a single Silvia, a double Silvia, a double Synesso and a triple Silvia. I know scales would be the most accurate, but its another device to have on the kitchen bench, and testing would be needed to know exactly what weight is ideal for which basket. These figures of course would probably change depending on kind of beans being used. I like to try different ones and there seems to be variations in dose needed according to beans. My mission at present is to avoid sweeping off too much ground coffee and to avoid having to put a few more beans into Rocky if I did not dose enough. There must be a simpler way. By the way, Im very happy with my shots, Im just trying to avoid waste and/or extra steps in the process. As a relative newbie, Im learning that consistency in technique is paramount.
  24. #24
    10,496
    Quote Originally Posted by 5D464C474E5D4B4E434E4D4E2F0 link=1297899281/22#22 date=1298779821
    The volume of ground beans is different to the volume of unground beans.
    The point is that I can gauge by the level of unground beans what becomes the correct volume when ground.
    Lets say that the unground beans reach the lip of the basket. Ground they dont reach that far.
    This topic has seen me pull out the scales to see if that is practical for me.
    Time-wise there doesnt seem to be much difference but as Richard A said, its one more device to have on the bench.
    Using the scales has been interesting though, as at one point I adjusted the grinder a bit fine so instead of going courser on the grind I decided to use the scales to use less beans for the next shot.
    As the beans aged, instead of grinding finer, I added more beans.
    This will only work so far though as eventually Ill be overdosing and so have to grind finer instead.
    "Theres more than one way to skin a cat."
  25. #25
    Dec 2010
    67
    I think Im becoming persuaded that I should get some digital scales. True, there may not be a need to use them all the time, but I need to have a picture in my mind of what a 21gram pile of beans look like versus a 18gram pile etc. Whether I use an actual scoop or basket may not be that important provided I use the same device consistently and know within a few beans how much to put into each different basket. Jaycar Electronics have a pocket-size one that measures up to 100gm for $49 and they are close to where I live (pictured). Id rather just get one locally than ship one in from O/S. Does anyone know of another local source?
  26. #26
    Jul 2008
    Port Fairy
    2,993
    Quote Originally Posted by 4E555F545D4E585D505D5E5D3C0 link=1297899281/24#24 date=1298782868
    The bay of evil was where mine came from at about $30 posted from Melbourne.
    100g ones are great for checking bean load weights and when I am using an electric grinder at home for a single brew I tend to use them each time to save wastage or having to add a few more beans later. If I was doing it again i would consider getting a set of 1000g (0.1g) ones for measuring brew water and finished weights for pourover coffees* ::)
  27. #27
    Dec 2010
    67
    Heres one for the "you got to see it to believe it" file. Im sitting here with a lovely single shot cap, after having used the single basket slightly heaped with beans as a measuring scoop. I had to level off excess ground beans before tamping! I honestly would not have believed that unground beans ended up so close to the volume of ground beans! What the...
    For the record Im using a single source Brazilian from Bellaroma, ground on 9th Feb and opened two days ago. Rocky is set to 7.
    Next time Ill use whatever basket I need leveled off with unground beans as my measuring standard and see how it goes.
  28. #28
    16,768
    Gday Richard..... :)
    Ive bought a couple of different sets of scales from this mob over the years. They are a very helpful and decent outfit and I have no problem recommending them to anyone.... 8-)
  1. Delongi Magnifica - Question on grind and quantity
    By Bootyinblue in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th August 2011, 11:06 AM
  2. Quantity of beans to buy?
    By MichC in forum General Coffee Related...
    Last Post: 30th January 2010, 06:42 AM
  3. Neat Gadgets
    By JamesM in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 30th January 2009, 02:25 PM
  4. advice needed on quantity of coffee
    By tommo in forum General Coffee Related...
    Last Post: 6th December 2008, 12:33 AM
