Results 1 to 5 of 5
Thread: Brew Gasket Direction
    Feb 2011
    30
    hey guys and girls,
    I recently got a new E61 beast to replace my old silvia. In the process, Im replacing the gasket/\/screens on both.
    I went into coffeeparts and picked these up, and the young lad there let me know that the side with the very slight angled edges go in on top or down below (ie facing the group or facing the portafilter). I was sure he said that it faced up as in this crude drawing:
    With this in mind thats how I whacked the new one into the e61, and havent noticed any leaking or had any problems. A couple of weeks later Im now getting around to doing silvia.
    On taking the gasket out, I noticed that the angles were facing the opposite way to what I had been informed, ie towards the portafilter. Are the e61 and rancilio gaskets to be installed differently?
    Sam
    Apr 2008
    Brisbane
    5,115
    Re: Brew Gasket Direction
    The drawing is the correct way to fit an E61 group head gasket
    Feb 2011
    30
    what about a rancilio group gasket? does it go in the same way?
    Apr 2008
    Brisbane
    5,115
    I am sure a Silvia user will comment (assuming thats what you meant)
    However in general, commercial type group heads have a different profile seal
    The angle is more noticeable on the rubber
    These type of seals are fitted with the angle facing down*
    Mar 2006
    703
    I dont recall exactly which way it goes in a Silvia, however, make sure you have a good look at the one that comes out and put new one in same way, they dont like working properly if in the wrong way.
    Also, compare thickness of original gasket and replacement one. It is much easier to put a spacer shim in, before you fit the replacement gasket, if the replacement gasket is thinner than the original, .... I know these things from experience... :-[
  1. breadmaker stirrer mods/direction
    By Matt_King in forum Roasters
    Last Post: 14th October 2009, 03:30 PM
  2. Direction and advice to what type
    By Caffeinated in forum Brewing Equipment (non-machine specific)
    Last Post: 7th June 2007, 07:50 AM
  3. Brew Gasket
    By Coffee_Kid in forum Brewing Equipment (non-machine specific)
    Last Post: 14th August 2006, 01:29 PM
  4. A new direction for cafes?
    By papalui in forum General Coffee Related...
    Last Post: 5th February 2005, 07:26 AM
