Results 1 to 4 of 4
Thread: Cuisinart kettle.
    Jul 2011
    1
    Cuisinart kettle.
    I wonder if anyone has had any experience with this kettle. My partner and I have just ordered a Presso and was looking for a new kettle to compliment it.
    Multiple heat settings, keep warm function and a filter of some description.
    http://www.cuisinart.com.au/prodView.asp?idproduct=454
    Cheers.
    Senior Member shapeshifter's Avatar
    Oct 2010
    Newcastle
    726
    Re: Cuisinart kettle.
    I have a Presso and use the Breville Variable Temp Kettle, I use the coffee setting so is 95 degrees, Ive put a temp probe on it and it gets down to 92 so is still fine for coffees through the Presso.
    Oh the answer, yes get one, it makes life so much easier than having to try and work out if the temperature is right from guess work :)
    Senior Member SniffCoffee's Avatar
    May 2010
    Canberra
    703
    +1 from me - I used to have a Presso too and used my Breville Kettle to make things easier.
    The other essential thing you should buy is a naked portafilter from the presso website - a great thing to use and an absolute bargain for $30.
    Sniff
    Jul 2007
    2,286
    Just boil the water in a saucepan and pour it in your cup, and then directly into the Presso.
    Voila--water at the correct temperature and hot cup to boot.
  1. Pour Over Kettle
    By PhatBoy in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 18th August 2010, 04:12 PM
  2. Cuisinart Coffee Grinder
    By adept22 in forum Grinders
    Last Post: 20th March 2010, 04:28 PM
  3. Cuisinart EasyPop
    By Stickleback in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 5th November 2009, 07:19 PM
