Results 1 to 4 of 4
Thread: Rocket Giotto In tank water softener
    Jun 2011
    290
    Hi All,
    Just saw the new in-tank softener demoed by Seattle coffee gear and was wondering whether any sponsors are thinking about getting these in as I would be most interested.
    Senior Member specialpants's Avatar
    Dec 2010
    310
    Re: Rocket Giotto In tank water softener
    I did buy an intank water softener from Jet Black Espresso not too long ago. Is that the same thing youre referring to (its a plastic canister with tiny little balls inside).
    14,665
    Quote Originally Posted by 5E5D484E444C415D4C43595E2D0 link=1319596488/1#1 date=1319597417
    No- as the tank anatomy is different, this type of filter wont work.
    The rocket product sounds like a resin softener cartridge of some description. ECA may well supply it in due course as they are working on some other funky Giotto accessories.
    Nevertheless, Id still be recommending a chat with Bernard of Bombora as hes probably forgotten more about filtration than Rocket will ever know ;)
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Quote Originally Posted by 373C263D27383A33540 link=1319596488/0#0 date=1319596488
    I rang up Espresso Company Australia about 2 weeks ago after finding out about the in tank softener.* They have it, but only as samples and I think they had 2 in total.* They are conducting their own tests to prove that it works before deciding if they will carry it or not.* I asked what price it would be if they did decide to stock it, they still have not worked that out.* So call ECA at the end of November and* you might get more details.* I ended up getting a softener that you can attach to the end of an existing puratap system instead from Bombora.* Its as simple as cut the outlet hose on the puratap and stick the cut ends into the softener and away you go...well soak the softener first...follow the instructions.* :)
  1. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 01:53 AM
  2. How do you tell when in-tank water softener needs replacing?
    By GCM58 in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th February 2011, 04:27 PM
  3. Rocket Giotto Premium Plus as a source of hot water. ?
    By dswatkin in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 27th December 2010, 03:06 PM
