Results 1 to 5 of 5
Thread: electricity costs for Bezzera Domus Galatea?
    May 2012
    1
    Been looking around the boards and cant find what Im after hence the post....
    Have a Bezzera Domus Galatea and love it to pieces but now looking hard at cutting energy costs at home.
    The machine is typically on for 6-8 hours per day and makes between 4 and 8 cups each day.
    My knowledge of electricity is that it comes from that white thing on the wall.... so I am sure there is someone a bit more tech savvy that would know the answer.
    Our power bill says we are paying 26.228/kWh.
    Many thanks in advance for any advice!
    Apr 2008
    Brisbane
    5,115
    Re: electricity costs for Bezzera Domus Galatea?
    Quote Originally Posted by 3E212720373B3232313133212D27540 link=1336182061/0#0 date=1336182061
    The main power drain is when the machine is turned on from cold
    Its similar to a 2 liter hot water jug
    Then it cycles for a few seconds as required to keep it to the set temp
    Cycling for 8 hours will probabably cost less than the initial cost of the first machine activation of he day
    Mar 2006
    703
    I have not seen inside the cover, so to speak, of one of these, but assuming the boiler is not insulated, you can gain some savings by the relatively simple process of insulating the boiler. It wont make any difference to the initial power usage on startup from cold, but once it is up to temp/pressure, it will increase the time between power on cycles while it is sitting and not being used, so overall you use less power. There is some good info already posted around the site, even a special thread devoted just to boiler insulation and noise damping. I have used the relatively economical Insulbrite material on my Silvia and my PV Lusso and it does make a difference.
    Mar 2012
    1,276
    for $15 you can buy a plug in power/cost meter from Aldi that will tewll you exactly how much it costs to run, and how much you save from any changes or mods.
    However , that $15 will keep your machine powered on for some time...
    Estimates:
    assume 1.5kW max power draw ?
    guess 10 mins to initially heat the boiler contents
    assume 10% duty cycle to keep machine switched on.
    So 1.5kW @ $0.263 = $0.394 per hour
    Warm up for 10 mins = $0.066
    8 hrs at 10% x $0.394 = $0.316
    Total cost per day* *= $0.382 .. ..or $2.70 per week .. (ESTIMATED)
    so, if insulation can reduce the heat loss to half, then you could save about $0.16 per day, ( half your usage)* but you could save much more by only switching it on* when its actually needed,..
    ..but i know that is not easy, depending on your usage "profile"
    Dec 2006
    Perth WA
    572
    So it costs two thirds of a commercial flat white per week.
    I had the same power cost concern with my Silvia. So I fitted a PID . I could see clearly that the main cost is the warm up, after that it was barely "sipping" the current. I notice the same "sipping" on the pressure guage of the Giotto once it has got to its operating temperature.
  1. New Bezzera Galatea Domus
    By Yelta in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th November 2009, 06:01 PM
  2. Bezzera Domus Galatea
    By paulie338 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 17th September 2008, 04:31 PM
  3. Bezzera Domus Galatea
    By hotdog in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 4th June 2007, 06:57 PM
