Results 1 to 12 of 12
Thread: Modifications to Portafilters...
    Jun 2011
    Adelaide
    92
    Dont know if this belongs here or not (let me know and I will change it if needed...)
    Im looking to cut the bottom off of my portafilter as the ridiculous cost of buying a naked portafilter for my Olympia Cremina is a little un-justifyable right now.
    Has anyone had any experience in doing this?
    And if so... did someone do it for you, where did you find them, how much did it cost, etc...
    Thanks. :D
    Aug 2004
    2,312
    Re: Modifications to Portafilters...
    any metal engineering shop will do it if you dont trust doing it yourself>
    Remember its an irreversible excercise so consider carefully the reasons why you want to do it and or what you are wanting to achieve
    Dec 2010
    Toowoomba QLD
    417
    I cut the bottom off mine (an EM6910). Did it using a drill press - drilled a ring of holes and then used a dremil to remove the final bits between the holes and smooth the edge. Came up really well with a bit of patience and care. The metal was quite hard and I did need to used a coolant/lube and sharpen the drill a couple of times. Metal working shops usually charge around $20 to do the job (but this will vary greatly depending on the shop).
    Pete
    Senior Member artman's Avatar
    Jun 2006
    2,409
    I did one of mine with a drill press and hole saw.* Another I had done by a mechanic with a lathe. The difficulty I encountered getting a business to do it is that they need a large lathe if the handle is still attached and most are not really interested in doing it and quote accordingly (almost the same as buying a naked). I found a small operator who did it for $5!
    Jul 2007
    2,286
    I did mine with a hole saw and an electric drill.
    By the time it was finished (about 10-15 minutes) the hole saw was cactus! (It was designed for wood and was purchased at the $2 shop.)
    With some smoothing and polishing with wet-and-dry, it looks fine.
    Apr 2008
    Brisbane
    5,113
    I had a forum buddy do mine on his lathe
    Jun 2011
    683
    Best thing is a rotary table on a milling machine, then the handle doesnt spin around like it does on a lathe (unless the handle comes off easily?). Im happy to cut it for you if you cant find anyone locally, Im in Melbourne.
    Senior Member NakiChap's Avatar
    Apr 2011
    Perth , WA , Australia
    352
    I did my original Expobar handle with a drill and hole saw
    Purchased the hole saw from Bunnings, worked fine I just finished it off with some fine sandpaper
    The hole saws came in a set of 6 different sizes which could be handy.
    Senior Member Bosco_Lever's Avatar
    May 2009
    QLD
    441
    Quote Originally Posted by 63474E4E4D4D7763475B4547280 link=1340339907/5#5 date=1340355679
    Um.... must be a top bloke, that forum buddy ;) ;)
    Senior Member C-man's Avatar
    Jun 2012
    Sunshine Coast, Peregian beach
    265
    I am just about to have a go at mine
    I was thinking angle grinder, but hole saw may be neater
    Jun 2012
    Tassie!
    30
    Hmmmm, Ive been wanting a naked pf, but couldnt afford it.
    Ill have a go at my single - never use it anyway so if I stuff it who cares!
    Hole saw sounds easiest- Ill let you all Know!
    Jan 2012
    48
    Hole saw wired for me, took ages as it was an old rusty saw blade. After a quick sand the inside is beautifull machine finished brass now. I had 4 portafilters for my 3 group so the choice was easy for me.
  1. MDF modifications
    By dsc in forum Grinders
    Last Post: 15th May 2009, 02:14 AM
  2. Silvia modifications
    By vector_director in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th May 2008, 10:26 AM
