Results 1 to 8 of 8
Thread: Temperature and/or pressure profiling
    Mar 2012
    1,275
    Subject moved from the BDB thread..
    Quote Originally Posted by Dennis View Post
    I consider temperature and/or pressure profiling in the context of espresso preparation to mean there is a programmable or manual means of altering the temperature and pressure during the course of the extraction, ie. in a similar fashion to lever machines, where I believe the concept of temperature and pressure profiling originated from.
    Keeping temp and pressure profiling separate.. I can see how a lever machine alows pressure profiling, but i fail to see how they facilitate any means of temperature profile changes..other than those initiated by flushing procedures. ??
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    The brew water loses heat to the huge group during the shot?
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Correctamundo!
    Mar 2012
    1,275
    ..The brew water loses heat to the huge group during the shot
    I understand that,... much like any other espresso machine..
    .but where is there .." a programmable or manual means of altering the temperature.... during the course of the extraction," ..
    Feb 2007
    4,512
    As an example if you hold the lever at a point say half way through the pull the water remaining in the chamber will be cooler than when you started and continue to cool. Holding that position for x seconds will give you y degrees in the cup. Hold the position for x plus another 5 seconds will result in a cooler finish to the extraction than y and you have just manually manipulated the temp profile.
    Jun 2011
    684
    interesting stuff. The limitation with this though as regards the topic is that with a lever, temperature and pressure are tied to each other during the extraction, there's not really a way to separate the two as if you want to allow the brew water to cool mid-way through a pour by holding back the lever you would also introduce a pressure dip at that point.
    Feb 2007
    4,512
    I agree it has limitations. What I find most interesting is that apart from the introduction of some electronics, we have come full circle in the development of espresso machines.
    Senior Member C-man's Avatar
    Jun 2012
    Sunshine Coast, Peregian beach
    265
    yep, pressure wise they just are simulating the lever, with a pre, a peak and a taper off.
    I find this works well with soft beans,
    but I can't find the answer for normal and hard beans, pressure wise 9-10 bar still wins with the harder beans
    I have even tried a 13 bar peak with harder beans without success
  1. Inlet Temperature Profiling…
    By DesigningByCoffee in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 17th September 2013, 03:14 PM
  2. Pressure profiling
    By potentialfig in forum General Coffee Related...
    Last Post: 3rd May 2013, 08:41 AM
  3. LM GS/3 Paddle Group Pressure Profiling
    By micksquires in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 13th March 2013, 08:32 PM
  4. EM6910 Pressure Profiling!
    By mwcalder05 in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 28th December 2012, 02:04 PM
