Results 1 to 5 of 5
Thread: Tamper and coffee freshness
    Jul 2004
    2,134
    Quote Originally Posted by Derkdigler link=1078801550/45#49 date=1108953444
    I just got my Silvia and D/L Rocky last week ...very happy...
    but i canít seem to get decent crema on my shots....any ideas as to why this might be??? *I think my grind is correct Öcould the useless plastic Tampa have something to do with it???
    Tamper could be a contributor.
    How fresh is the coffee?
    What type of bean (some just produce more crema).
    How is the taste?
    Aug 2004
    Victoria
    139
    Re: What Coffee Equipment do you all have?
    Hey,
    The coffee freshness i am not sure on as these are the beans i got from Mocopan...so they could well have been roasted awhile ago. Bean type is Pasquale Blend. Not normally what i use..most of the time i go with Kenya AA or East Timor Organic. The taste is slightly bitter.... the grind setting i have at 13 or 14 is this too fine??
    DD
    Jul 2004
    2,134
    Well... I would suggest you play a bit with the grind (my Rocky usually hovers between 8 and 10).
    Bitterness is not usually a good sign.
    Dont know much about the beans you have, but you would hope that Mocopan are selling fairly fresh stuff (and of course you have had them for less than 7 days)
    The pour rate is another indicator on whether the grind and pack is correct. Even with the plastic tamper, I suggest filling the PF, tapping on the bench to level off. Scrape any obvious excess grounds off the top. Tamp, load and draw shot.
    The flow should be consistent but not too fast.
    The figure bandied around a lot is 30ml in 30 seconds.
    EG: http://www.coffeeuniverse.com/tips.html
    See how you go.
    17,463
    Quote Originally Posted by Derkdigler link=1078801550/45#51 date=1108957096
    Hey,
    DD
    Hi DD,
    Its a bit difficult to estimate what one grinders setting is equivalent to on another grinder even of the same make. However, if you "zero" your Rocky (rotate setting until burrs touch with grinder turned OFF), note the position, it is then possible to compare settings within the ballpark at least.
    Doing this with my Rocky the zero ends up at -3 on the scale, where the standard setting for my Mokita with a 57mm PF is 11 +/- 1 notch. This is with freshly roasted high quality coffee and a tamp of approx 10Kg. So, this equates to 14 notches from where the burrs touch.
    Since a Silvia has a commercial style 58mm PF, I would expect it to require a setting that is some units below that of 11. What "Fatboy" refers to as hovering between 8-10 sounds pretty right for 58mm PF machine. If I was you, Id start with some freshly roasted beans that you know and then take it from there. Trying to get everything set up with unknown beans is really just shooting in the dark.
    A Silvia is a great machine and if everything is being done properly then Silvia will certainly pay dividends. All the best,
    Mar 2005
    2,165
    Re: Tamper and coffee freshness
    Bitterness is often related to overextraction, i.e. too much water going through the coffee, but Im sure stale beans wouldnt help (get some fresh beans and try again). How long do you run the machine for when brewing?
    As youve suggested, the tamper could be an issue - if your tamper is undersized then youll have to tamp numerous times to pack it relatively evenly, but even then there will be pressure variations with some areas being packed harder (and therefore underextracted) and some looser (an easy path for the water, leading to overextraction). Most people seem to be able to get acceptable results with fresh beans, correct grind and correct brew time, so start with these, but you may want to look at getting a proper tamper at some stage to help with even extraction and therefore consistent results.
  1. Coffee age and freshness
    By Barry_Duncan in forum General Coffee Related...
    Last Post: 20th April 2011, 06:50 PM
  2. Coffee Freshness
    By carloz in forum General Coffee Related...
    Last Post: 23rd November 2008, 09:08 PM
  3. Coffee Freshness at GJ
    By thegoodies in forum General Coffee Related...
    Last Post: 29th January 2008, 04:52 PM
