Results 1 to 4 of 4
Thread: Bringing a Water softener back to life
    Senior Member skydragondave's Avatar
    Apr 2010
    105
    Just acquired this softener from a closeout coffee shop that's probably never recharged or done any maintenance on their equipment. Looking inside I see scale, black bits, and general nastiness inside. Do I have to remove and replace the IX beads, or can they be soaked in some sort of cleaner and re-used? Can I just descale the tank and strainers and give it a quick polish, or is there anything else I need to do before throwing salt into it?
    Thanks very much
    Oct 2011
    1,376
    Re: Bringing a Water softener back to life
    Some ion exchange resins can be regenerated, but it depends on what type it is (speaking in a general sense; not specifically this application). If its old, I'd be tempted to replace it anyway ( if you can).
    Apr 2010
    105
    OK, on quick search I'm finding a ton of different resins available, which is most appropriate for this softener? Do I have to select it based on a water quality test of where I'm putting the softener, or am I looking in a narrow band of resins to use in coffee machines.
    Commercial non-sponsor link removed per the http://coffeesnobs.com.au/general-ne...icy-rules.html
    Like some of the nuclear grade crap on this site for $400 a foot, OK obviously I won't need. But is there a particular type I should be selecting from?
    Last edited by Javaphile; 17th March 2013 at 02:56 PM. Reason: commercial link removed
    Oct 2011
    1,376
    In an industrial setting, an ion exchange vessel's design is highly dependent on the characteristics of the resin. In a domestic setting the requirements are different, so they are probably somewhat overdesigned in some respects.
    Best bet would be to try and contact the original vendor or manufacturer, and change like for like. Otherwise, contact a specialist vendor and ask if they can supply something suitable.
    Key parameters are likely to be diameter, bed depth, flowrate and application (I.e. what are you removing, and how concentrated it is); although this might be overcomplicating it for domestic use.
    For reference my experience with ion exchange resin is primarily industrial and theoretical - I don't work with it, or sell it.
  1. Maintenance of water softener/filter on end of water intake pipe
    By andrew in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 21st March 2011, 12:53 AM
  2. Water softener cartridges
    By Gavin1 in forum Brewing Equipment (non-machine specific)
    Last Post: 21st June 2008, 10:19 PM
  3. Need help bringing Silvia back to life
    By dmaxdmax in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 14th May 2008, 08:09 AM
  4. ROCKY DEAD... Help me bring him back to LIFE!
    By rayzurhed in forum Grinders
    Last Post: 4th October 2007, 10:06 PM
  5. Water softener unit
    By Paolo in forum Brewing Equipment (non-machine specific)
    Last Post: 31st January 2007, 08:33 PM
