Results 1 to 34 of 34
Thread: descalling...when??DAYLIGHT SAVINGS
    May 2006
    62
    as i just found out with 2mcm, descale your machines every six months!..so when we set our clocks an hour foward in the coming months and change our smoke alarm batteries,im descaling my machine...today the amount of green liquid that came out in 10 months of use was surprising...oh and you can taste the difference..so descale today and youll have no sticking valves in six months time...!
    May 2006
    62
    Re: descalling...when??DAYLIGHT SAVINGS
    and i used filtered water...
    Feb 2005
    2,604
    Thats a handy hint, Mr Fox. What is your location?
    Does your filter have an ion exchange?
    --Robusto
    May 2006
    62
    melb here.......and the filter is a brita 5lt cask with a digital timer to replace the filter..every four to five weeks..
    Nov 2006
    1,673
    Errm, I do my descaling once a month. But then I live in Adelaide and I do use rainwater too.
    Aug 2004
    2,312
    Just a thought...
    a)
    For those of you with semi commercials with internal water reservoirs that dont have a "water softener" on the end of the water pick up line, there is usually no reason why you cant simply add one....its only a push on fit onto the end of the silicon tube.
    Instead of descaling the machine then, you simply regenerate the softener from time to time depending on the quality of your local water and the amount of throughput your machine is subject to. Its (a lot) easier *than descaling the machine.
    We have them, as they are standard equipment on our Diadema Juniors and Unico Splendors.
    b)
    For those of you with machines connected to the mains, we have simple "in line" water filter kits that release an anti-scaling agent. Its a lot easier to change the filter (a bayonet fitting & only a few seconds to replace) than to go descaling the equipment.
    Its easier to stop the stuff forming in the first place (to a greater degree) than it is to remove it.
    Regardz,
    FC.
    Feb 2006
    2,334
    absolutely....try and prevent anything as much as you can. fix the root cause, and if it still happens, atleast it is a lot more delayed and less frequent.
    much like how dosing and distribution if often neglected. no amount of leveling will help you fix up a dodgy distribution. fix the root cause.
    10,496
    Im lucky my Expobar has the softener already as descaling was one job I wasnt looking forward to.
    Ive regenerated the softener once already and it was definitely easy.
    I dont see why all machines dont have them.
    As FC said "its only a push on fit onto the end of the silicon tube".
    14,665
    Quote Originally Posted by Thundergod link=1175073473/0#7 date=1175651922
    TG- you should regenerate the softener about every 3 weeks with normal use...
    2mcm
    Flo
    Flo is offline
    Aug 2006
    330
    Hey 2mcm...what is the story re: softening and Giotto? Recommended or not?
    10,496
    Quote Originally Posted by 2muchcoffeeman link=1175073473/0#8 date=1175653955
    2mcm
    What do you consider normal use?
    *Schedules next recharge*
    14,665
    Quote Originally Posted by Thundergod link=1175073473/0#10 date=1175664032
    2mcm
    Do it every three weeks TG...you cannot overservice the gel....
    10,496
    Thanks.
    (Damn - need a spreadsheet now for all my cleaning tasks)
    14,665
    Quote Originally Posted by Flo link=1175073473/0#9 date=1175662272
    Yes Flo- recommended....The unique water pickup in the Giotto means that you should fill the machine with filtered, softened water....FCs in tank softeners are sadly not suitable as there are no silicon water tubes....
    2mcm
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Quote Originally Posted by 2muchcoffeeman link=1175073473/0#13 date=1175665893
    2mcm
    Not sure I understand - if water softeners are recommended for the giotto, what are my options please Chris? btw - I already use filtered water from a pretty good under-sink system.
    3,498
    Quote Originally Posted by Dennis link=1175073473/0#14 date=1175670982
    Dennis,
    The standard under sink units do nothing to remove hardness (prevent scale build up in your boiler).
    The options are :
    Britta Jug (filter replaced frequently)
    Water softener commercial machine size (recharged with salt every month or so)
    Water softener cartridge (replaced at recommended intervals)...
    F.C sells the last two.
    14,665
    Sounds great Dennis. I was suggesting that because an in tank softeners are impossible for a Giotto, owners should use filtered, softened water. Sounds like yours comes from your kitchen tap! Expobar, Unico and Diadema all have in-tank softeners and they can easily (and I would suggest should) be added to Silvias and any other machine with silicon water tubes living in tanks....
    I use a jug...
    One thing to keep in mind is that Reverse Osmosis water KILLS machines (were looking at you, WA residents ;)) unless you then add ions to the filtered product and in the correct proportions....
    Feb 2007
    4,512
    Ok, am now starting to panic...I had a laugh
    Have just come up from under the sink and we have a clearwater, twin cartridge filtration system. I understand this would not soften, but just keep out the yukky stuff.
    Dont want a brita - look at me...I cant fit another appliance anywhere.
    Should I just pm cosmorex and hope he has something I can throw in the tank???
    14,665
    No can do Dennis- why not add a softener cartridge to your under sink?
    Feb 2007
    4,512
    Quote Originally Posted by 2muchcoffeeman link=1175073473/15#18 date=1175673369
    Thanks - will contact clearwater to investigate how this can be achieved
    Feb 2005
    2,604
    That brand you mentioned Dennis (which supplied the under-sink filtration on my boat: silver-impregnated activated charcoal to get rid of the taste of stagnation and sundry other tastes--works well) and they do have a softener cartridge, but I think it is disposable and therefore costly.
    Youre probably better off using the proprietary ones which recharge with salt.
    -Robusto
    Mar 2005
    169
    Quote Originally Posted by Fresh_Coffee link=1175073473/0#5 date=1175571716
    Just a thought...
    a)
    Instead of descaling the machine then, you simply regenerate the softener from time to time depending on the quality of your local water and the amount of throughput your machine is subject to. Its (a lot) easier than descaling the machine.
    Regardz,
    FC.
    I have the Unico Splendor with the softener attached, how do I regenerate it? (scratches head trying not to look too dumb)
  23. #23
    Flo
    Flo is offline
    Aug 2006
    330
    2mcm
    I just use a Brita Jug with the Maxtra cartridge for filtration...Ok or should I be using something else?
  24. #24
    10,496
    So as my Expobar already has the softener in the tank is my Brita filtered water just overkill?
  25. #25
    3,498
    Quote Originally Posted by Thundergod link=1175073473/15#23 date=1175692615
    Thundergod,
    All types of scale removal filtration (with the possible exception of reverse osmosis - and of course distillation) only reduce the percentage of calcium. Even my commercial water softener leaves some calcium salts....
    So the more stages of filtration the better... And as FC said - it is easier to stop the stuff forming in the first place.
  26. #26
    10,496
    Good to know.
    Thanks.
  27. #27
    Feb 2007
    149
    Ok, regenerating this thread. I removed the cartridge from my Expobar Minore when I bought it. It believe it might have been the softnener cartridge. I was adviced it was OK to remove it since the resulting pour would come out yellow... I use a Sunbeam filtered water dispenser but now having now read this - have I done a bad thing even though I use filtered water?
    If I need to put it back, does it matter which tube it goes onto (there are 2 in the Expobar)?
    Been a year now since I bought it.... *nervous*
  28. #28
    16,672
    Quote Originally Posted by 30in30 link=1175073473/15#26 date=1212406423
    Gday 30,
    Seems like strange advice to give you :-?..... But anyway, you need to reconnect it to the tube that leads to the suction input of your pump. The other tube will be the Bypass line from your OPV.... :)
    Dec 2004
    Earth!
    15,446
    Many filters are one-way. Look for an arrow on your filter indicating the direction of water flow. If theres no arrow then it probably doesnt matter which way its hooked up. :)
    Java "Filtering reality" phile
  30. #30
    10,496
    The Expobar filter sits at the end of the line.
    So it can only be connected from the right end.
    The trick is to pick which of the two tubes.
    If you cant see which one is drawing the water out then put in the blind filter and see which tube puts the water back into the reservoir when the OPV kicks in.
    It will then be the other tube.
  31. #31
    Sep 2006
    Sydney Straya
    144
    Just an observation...
    On my pablo, the tube for the filter has a square cut end while the return tube is cut at an angle.
    The filter tube is also a couple of cm longer.
  32. #32
    May 2008
    41
    Quote Originally Posted by 2muchcoffeeman link=1175073473/15#16 date=1175671923
    I use a jug...
    This is what I use. Just boil the jug the night B4.
  33. #33
    Feb 2007
    149
    Mal/Javaphile/Thundergod/Wingnut --> Thanks a million guys, will take advice and put it back in.
    Wingnut, inspected the tubes and sure enough its exactly as you described.
    Hornet, its actually normal practice for me to boil water, put in filter dispenser, then pour into the machine. I am pedantic? Yeah, probably ::)
    Cheers, Andrew
  34. #34
    May 2005
    1,946
    Hi Guys,
    All of these are solved problems and I think that many of you are at the stage where you might be interested in tackling The Insanely Long Water FAQ.
    A few things that I took from it:
    (a) Brita filters are not designed to remove scale. They will do so, but getting good performance out of them requires replacing them more often than youd think.
    (b) The ion exchange softeners at the end of the silicon tube in your tank probably needs to be recharged more often than youd think, too.
    Jims conclusion:
    I personally think home machine users are better served using neutral or harder water and preventively descaling. At home use levels, the 5 gram scale accumulation criterion will only require monthly to quarterly descaling, and the coffee taste will be at its best whenever the water is at 90/50 or above, since the machine will reduce it to that level by heating it. Whether or not to soften the water down to this level depends on how hard the tap water is; if the water is very hard, descaling could become a weekly chore, and such a partial softening could be preferable.
    Theres several ways to do this. The conceptually simplest is to boil the water for a few minutes; this removes hardness in excess of coffee levels. I use my Brita jug for all drinking water, since my water is cloudy from old pipes; its incomplete softening, or that of the hose end softener in a warm tank, also makes for a tasty espresso. Finally, tap water can be diluted with RO water to reach any hardness level one wants.
    Those of us with HX machines would do well to remember that scale can potentially clog up the thermosyphon and make your group run at a lower temperature than youd like. I still havent tackled the "mushroom" in my group, but will do so at some stage.
    Luca
  1. Time Zone and Daylight savings.
    By Andy in forum General News
    Last Post: 29th October 2007, 12:44 PM
